Home > Technical (L322) > Is this the best battery for 2010 3,6 TDV8?
Seabass
Sweden
Hi all, been searching and reading several battery related threds on here but to be sure is this the right battery and will it fit in my TDV8?
I'm thankful for input from someone who's recently changed their battery in a 2010+ car Thumbs Up
http://www.ebay.com/itm/VARTA-SILVER-DYNAM...5412ca38fa 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Swedish LR club member #5333
Post #295270 26th Nov 2014 10:50am
Has your vehicle had the JLR update to a "Glass Mat Battery"? sir
read here...
http://www.fullfatrr.com/forum/topic28682....gm+battery
Post #295271 26th Nov 2014 11:09am
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
I replaced My genuine LR battery with Odyssey PC2150S. A perfect battery for cold climate and a high electricty consumption.
SPECIFICATIONS
Pulse (5-second) Hot Cranking Amps (PHCA) 2150
Cold Cranking Amps (CCA) 1150
20Hr Nominal Capacity (Ah) 100
Reserve Capacity Minutes 205
Dimensions L x W x H (in) 13.00 X 6.80 X 9.41
Metric Dimensions L x W x H (mm) 330.2 X 172.7 x 239.0
Weight (lbs) 77.8
Weight (kg) 35.3 Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #295275 26th Nov 2014 11:30am
Seabass
Sweden
read here...
No sir, I don't think ever was an recall on that I Sweden or so I'm told Confused
Edit: Got an answer from LR Sweden now and that q159 was not for my car but for a number of cars produced between specific vin numbers.
You being an experienced professional, will the battery on my link fit in the car Craig? 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #295278 26th Nov 2014 11:40am
Seabass
Sweden
Thanks for the tip but If the Varta will do the job I don't want to spend the extra money although the Odyssey seems to be top notch Thumbs Up 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #295279 26th Nov 2014 11:48am
Seabass
Sweden
So.. Ordered this battery and I will make it fit Razz 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #296350 1st Dec 2014 6:31pm
It should fit, just make sure you have NO WIND when you put the bonnet in access mode and clean out the battery tray area as well. Also dont drop a bolt down there or you may never see it again!
As an aside do you use a block heater or just the park heater? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296357 1st Dec 2014 6:52pm
Seabass
Sweden
I will make sure, only use the park heater sir. 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #296359 1st Dec 2014 6:54pm
Sandyt
Guess don't have beans for breakfast that should solve the wind probs Thumbs Up
Post #296362 1st Dec 2014 6:55pm
Bryan N
England 2010 Range Rover Vogue TDV8 Santorini Black
Just for future reference, Service Action Q159 - the factory recall to correct a software fault and fit a different battery - only applied to the 2010 MY 3.6 TDV8 between VIN LM306631 and VIN LM334416.
That Service Action expired(!) on 30th September 2014 so I'm pleased I discovered last December that the dealer who sold us the car had 'forgotten' to do it! Rolling Eyes
Post #296380 1st Dec 2014 7:15pm
In your climate I'd be tempted to do the Dan method and stick a battery in the spare compartment at the rear as well unless you've had the recall that borks the fbh to only run 15mins Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296389 1st Dec 2014 7:41pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
with ref to the spare Battery compartment in the rear, where is it? do you have to run all the wiring through from the front battery to put them in parallel or is some of it part wired?
i replaced my 10My 3.6 battery with a Numax Leisure from Tayna 110Ah, 1000MCCA. £75
http://www.tayna.co.uk/Numax-Leisure-Batte...mp;A-7=110
i have run all my LRs on Numax Leisure Batterys for the last 8 years. for the ££ they are great size/capacity and last well. Cheers
James
Post #296907 4th Dec 2014 8:37am
The spare battery area I refer to in the rear is an area that's been found to take a normal average sized car battery with very little modification.
Basically it involves removing the cubby pocket from the drivers side of the boot floor where the tow arm bits would normally go.
Wiring only needs to be done upto the fuse board in the boot so about 40cm of red and black are needed Smile
Can I ask why you chose a leisure battery instead of a normal battery as iirc leisure batteries aren't suited to vehicle use?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296913 4th Dec 2014 9:01am
Seabass
Sweden
So I replaced the battery today, it was tight so I had to rebuild the positive fuse connector to be able to connect the positive clamp due to the oversized battery.
I also fitted a cetek fast connect panel for easy charging and it also has a indicator so it's easy to see when a top up charge is needed without having to open the bonnet, witch is practical for my wife to use when I'm away at work for longer periods.
It's also a good feature to have if the car goes completly power empty when locked and alarm on, just put in the charger and unlock Thumbs Up
Post #297006 4th Dec 2014 6:10pm
JST
thank you will look at info, was thinking smaller battery there that i could put an inline feed on to select when to use it.
the leisure battery will take a harder kicking down on power and will recover. Someone far more knowledgeable than me on the subject suggested the make up of Leisure batterys means they work as std battery too and can take greater discharge.
i run a tractor, 3 x 90s, a 110 on Leisure battery and have done for a considerable period of time. seems to work well for me so made sense to put the RR on one too. Cheers
James
Post #297014 4th Dec 2014 6:53pm
