![]() | Home > Technical (L322) > Rain Sensor |
Hi Jim and welcome to the forum. I'm pretty sure that it should work with an "generic" windscreen but can't be sure. I'm hoping that someone on this forum does know otherwise there is only one way to find out !!!
AFAIK your car should have rain sensing on the windscreen , auto lights came a bit later. What make is the wind screen? the genuine ones were made by Pilkington but have a Land Rover logo on them .
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
Hi, right... You will need the plastic holder (which comes bonded to your OE screen!) to be able to fit the replacement sensor to your new screen... I have just had the "wrong windscreen" fitted to my new car. The newly fitted windscreen did NOT have a rain sensor "so this is what we did"
Jim Member Since: 04 Feb 2013 Location: Tasmania Posts: 25 ![]() ![]() ![]() |
Gday.
What other info would you like Jim |
Not quite sure how the Hawkeye accesses vehicle systems, but I am going to guess that it does not read the vehicles CCF and then only display systems that are actually installed - it will display all possible systems within an ECU. What do you mean by "My Faultmate has the software to diagnose it" (in which menu are you seeing the rain sensor)?
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
So the IID tool will activate it |
Yes - on all L322s except the very earliest L322s (which have only been 2002MYs in our experience- so with a 2003 you should be OK) |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1550 ![]() ![]() |
I know this is an old thread but.... The Rain Sensor is under Other Systems->Rain Sensor for that year model but I can't recall if one can actually diagnose it. I'd have to check mine but I think all that is reported is information on the sensor. Do early model L322 Rangies have a CCF ? Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
all FF's have a car configuration file,
Thanks Stan.
https://www.gap-diagnostic.com/products/iidtool/
I had a look at the Rain Sensor with Faultmate today - and learned something.
Well, after adaption, my rain sensor is working properly again. It is no longer necessary to have it on the most sensitive setting in the hope it might wipe the screen. I've had to turn the sensitivity right down.
