Home > Technical (L322) > Rain Sensor
Jim
Australia 2003 Range Rover Vogue Td6 Java Black
Rain Sensor
Gday from way down south in Tasmania.
I have a 2003 L322.
A previous owner has put in a cheap generic windscreen. It has no rain sensor module behind the rear vision mirror. All the wires are there even the fuses are still in place. My Faultmate has the software to diagnose it.
My question is if I get a new sensor module, plug it in and stick it to a non genuine windscreen will it work?
Any thoughts and ideas will be gratefully appreciated.
Jim Series 1 1948 (oldest Land Rover in Tasmania)
Series 1 109 1958
series 2 swb petrol 1965
series 2 swb diesel 1965
series 2 lwb petrol dormobile
series 3 lwb ute
series 3 lwb ute (Holden engine)
110 defender auto 1994(sold, now living in NZ)
130 defender 1994 (Isuzu 4BD1)
Range Rover 1990 petrol
Range Rover 1994 LSE diesel 300tdi
Range Rover 2003 L322 td6 vogue
Range Rover 2002 L322 td6 HSE
Defender 119 2015 (last one in Tasmania)
Post #292855 14th Nov 2014 6:37am
ebajema
Hi Jim and welcome to the forum. I'm pretty sure that it should work with an "generic" windscreen but can't be sure. I'm hoping that someone on this forum does know otherwise there is only one way to find out !!!
Have you seen the screen next to an original LR screen and are there big difference in tinting, thickness etc. as far as you can see. I believe rain sensors come from a few OEM manufacturers and go to all the various car makers so I'd expect that most sensors should work on most cars. Since they are optical, it is good to find out whether the optical properties for the generic and original screens are more or less the same. MY 2010 5.0 SC Galway green and sand interior!!
Post #292858 14th Nov 2014 6:57am
AFAIK your car should have rain sensing on the windscreen , auto lights came a bit later. What make is the wind screen? the genuine ones were made by Pilkington but have a Land Rover logo on them .
I read your post on AULRO and I got three screens out of Shannon's six months ago because O'Brians hadn't a scooby how to fit it properly , maybe have another go at them because you can argue that the screen is structural as it provides stiffness to the upper body work and a substandard one will compromise it's structure . Long shot I know . 2008 MY Supercharged
Post #292866 14th Nov 2014 7:58am
Hi, right... You will need the plastic holder (which comes bonded to your OE screen!) to be able to fit the replacement sensor to your new screen... I have just had the "wrong windscreen" fitted to my new car. The newly fitted windscreen did NOT have a rain sensor "so this is what we did"
Took the original sensor holder (bonded on old screen) and cut it off using a knife blade. Carefully measured it then bonded it back onto the "new windscreen" fitted the sensor and bob's your uncle's dog!!! It all works perfectly Thumbs Up Thumbs Up Thumbs Up
WHY Shocked Shocked Shocked I hear you all ask would Craig have a NON STANDARD windscreen fitted Shocked Shocked Shocked
I wanted to fit a genuine OE JLR solar reflective windscreen to my car (old one stone chipped but standard glass) the solar reflective glass is only made for the middle east market so does NOT have a rain sensor... Simples Thumbs Up
Post #292892 14th Nov 2014 9:49am
Jim
Gday.
Thanks for the info. Im going to my local LR dealer. He'll sell me a rain sensor module for $100 AU. Ill stick it on and give it a go. I need to check if he can get me the piece that you cut off the windscreen as well, otherwise I'll get one from the wreckers here in Australia.
Cheers
Jim.
Still looking for any other info!!! Series 1 1948 (oldest Land Rover in Tasmania)
Series 1 109 1958
series 3 lwb ute
Post #292895 14th Nov 2014 9:57am
What other info would you like Jim Question
Post #292898 14th Nov 2014 10:03am
SteveMFr
Site Sponsor
Not quite sure how the Hawkeye accesses vehicle systems, but I am going to guess that it does not read the vehicles CCF and then only display systems that are actually installed - it will display all possible systems within an ECU. What do you mean by "My Faultmate has the software to diagnose it" (in which menu are you seeing the rain sensor)?
Just want to keep you from spending money on a rain sensor that will not work for you. The wiring is there on all L322s (I believe) but if your RR was delivered w/o a rain sensor it will not be activated in the CCF (car configuration file). In this case, even if you plug a sensor in it will do nothing as the sensor won't be 'seen' by the RR. If this were the case, you could have it activated - but you would need diagnostic equipment with this capability: OEM IDS, Autologic, BBS Faultmate, or our IIDTool.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #292946 14th Nov 2014 1:17pm
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
So the IID tool will activate it Razz
Post #295759 28th Nov 2014 8:00pm
SteveMFr
Site Sponsor
Yes - on all L322s except the very earliest L322s (which have only been 2002MYs in our experience- so with a 2003 you should be OK)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #296275 1st Dec 2014 11:38am
p38arover
Australia
I know this is an old thread but....
The Rain Sensor is under Other Systems->Rain Sensor for that year model but I can't recall if one can actually diagnose it. I'd have to check mine but I think all that is reported is information on the sensor.
Do early model L322 Rangies have a CCF ? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #438120 12th May 2017 10:09am
all FF's have a car configuration file,
from the GAP site,
Post #438129 12th May 2017 10:56am
p38arover
Australia
Thanks Stan.
I can't find that page on their site.
EDIT: Found it Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #438135 12th May 2017 11:10am
https://www.gap-diagnostic.com/products/iidtool/
scroll down a bit .. Thumbs Up ... - .- -.
Post #438138 12th May 2017 11:16am
p38arover
Australia
I had a look at the Rain Sensor with Faultmate today - and learned something.
There is a Rain Sensor Adaption feature to recalibrate the sensor after a windscreen change. Mine hadn't been done when the screen was changed a couple of months back. I'll just have to wait for some rain (forecast for tomorrow) to test it, we haven't had rain in weeks.
The Faultmate can read faults (but not clear any) and inputs for the sensor, e.g., are the wipers parked. Mine indicates a failed RLS whatever that is (I will have to check RAVE). I'm sure fault wasn't there before I did the adaption. I'll check it again after some rain and use. There's no point in testing it with a garden hose. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #438249 13th May 2017 10:48am
p38arover
Australia
Well, after adaption, my rain sensor is working properly again. It is no longer necessary to have it on the most sensitive setting in the hope it might wipe the screen. I've had to turn the sensitivity right down.
At least it rained yesterday afternoon so I could test it - the sky was cloudless today. Very Happy Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #438456 15th May 2017 1:11pm
