Home > Maintenance & Mods (L322) > MOT tomorrow....
MOT tomorrow....
Ok its time for the annual pilgrimage to our local testing centre, 2 cars going in on the same day. Mine and Swmbos.
Fingers are crossed, all should be OK, will have a wander round hers as no doubt its missing a headlamp or something else she has failed to notice....
Points of interest on mine will be a slight knock on the rack, the local mechanic thinks its so slight it should be OK, not fancying 2k on a new one..... Also am interested to see how the brake lines fare. But other than that it seems in fine fettle. There is nothing that can't be fixed with a hammer😜😜
Post #292558 12th Nov 2014 7:24pm
good luck Mark...i'm sure all will be ok Thumbs Up .. ... - .- -.
Post #292560 12th Nov 2014 7:29pm
RiccartonRR
As Stan said - Good Luck Thumbs Up
Have you accidentally left a £20 note on the passenger seat by any chance? Whistle
Post #292562 12th Nov 2014 7:34pm
Googsy
Good luck Mark Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #292565 12th Nov 2014 7:38pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Good luck, I really need to take mine in as well and same fears over the brake lines... 4.2 Supercharged Vogue SE
Post #292569 12th Nov 2014 7:50pm
Welshdragon
As others have said, good luck fella, sure it be fine Thumbs Up If it dont work.......burn it!
Post #292572 12th Nov 2014 7:57pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Mine came back with an advisory on the lower front suspension arm bushes this afternoon.
There's a link to them below should anybody else have the need to replace theirs.
http://britishparts.co.uk/products/9415-suspension-arm-RBJ500920
Post #292587 12th Nov 2014 8:25pm
Welshdragon
^ At that price its not a genuine LR bit, more britpart! Wink If it dont work.......burn it!
Post #292600 12th Nov 2014 9:10pm
Mark L
If it lasts more than 4 years it'll be doing better than the factory fitted pair that are on it now! Shocked
Post #292601 12th Nov 2014 9:17pm
Cheers chaps Thumbs Up
Got an mid morning slot, which is a bit tactical.....
Not so early he is in a bad morning mood
Not so late in the morning he's hungry
Not late in the day so he isn't knackered..... There is nothing that can't be fixed with a hammer😜😜
Post #292602 12th Nov 2014 9:19pm
Very Happy Very Happy Very Happy
Both cars through! Just a couple of advisories, tracking on swmbos skoda is a bit off, so has worn a perfectly good michelin on the inner edge sitll legal though!
The ffrr has advisory on front brake pipes, slightly corroded where they join the flexi. Thinking, cut out a section and put a join to a new section behind the wheel arch liner, is this a decent enough fix, local indy quoted me £80 which seems fair enough. The alternative is a couple of complete new front pipes, from the stealer. Which I am waiting on a price. They aren't that bad that they failed mostly jus the paint peeing off the pipe Thumbs Up
Rack aparently is ok, minimal play👍👍 There is nothing that can't be fixed with a hammer😜😜
Post #292797 13th Nov 2014 6:06pm
ok until next year then.. Wink ... - .- -.
Post #292799 13th Nov 2014 6:16pm
Well done on the two passes, play in the rack is more than likely a rack end, now it's started it will degrade quickly, they are pretty cheap and easy to do especially if they have it apart to do the brake pipes.... Pete
Post #292801 13th Nov 2014 6:22pm
Chauch
Good news, well done Thumbs Up 4.2 Supercharged Vogue SE
Post #292803 13th Nov 2014 6:34pm
I know there are joint couplers available to do this but I've never seen a garage use them, why would you want to add another potential leaky area into a safety system. Best pay the mechanic £80 to do the work if you're not sure about doing it yourself...What price safety?!!!
p.s. might be worth changing the flex pipes while you're at it Thumbs Up
Post #292808 13th Nov 2014 7:05pm
