Home > Maintenance & Mods (L322) > MOT tomorrow.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
good luck Mark...i'm sure all will be ok .. ... - .- -.
12th Nov 2014 7:29pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
As Stan said - Good Luck
12th Nov 2014 7:34pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Good luck Mark Present :2008 TDV8 HSE
12th Nov 2014 7:38pm |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
Good luck, I really need to take mine in as well and same fears over the brake lines... 4.2 Supercharged Vogue SE |
12th Nov 2014 7:50pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
As others have said, good luck fella, sure it be fine If it dont work.......burn it!
12th Nov 2014 7:57pm |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 |
Mine came back with an advisory on the lower front suspension arm bushes this afternoon.
12th Nov 2014 8:25pm |
^ At that price its not a genuine LR bit, more britpart! If it dont work.......burn it!
12th Nov 2014 9:10pm |
If it lasts more than 4 years it'll be doing better than the factory fitted pair that are on it now! |
12th Nov 2014 9:17pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Cheers chaps
12th Nov 2014 9:19pm |
13th Nov 2014 6:06pm |
ok until next year then.. ... - .- -.
13th Nov 2014 6:16pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Well done on the two passes, play in the rack is more than likely a rack end, now it's started it will degrade quickly, they are pretty cheap and easy to do especially if they have it apart to do the brake pipes.... Pete
13th Nov 2014 6:22pm |
Good news, well done 4.2 Supercharged Vogue SE |
13th Nov 2014 6:34pm |
I know there are joint couplers available to do this but I've never seen a garage use them, why would you want to add another potential leaky area into a safety system. Best pay the mechanic £80 to do the work if you're not sure about doing it yourself...What price safety?!!! p.s. might be worth changing the flex pipes while you're at it |
13th Nov 2014 7:05pm |
