Home > In Car Electronics (L322) > Accessory +12v Purple / White on cassette? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi all, I'm adding a TPMS to the 'Git' after I drove a few miles on a flat tyre without knowing it, until I came to a roundabout . I had a mate in the car, so the radio was off, we didn't hear anything, feel anything, the first that we knew about it was when we turned a corner. I'm just glad that it was a roundabout and not a sweeping bend on a country lane, otherwise this would be coming to you from hospital.
27th Oct 2014 6:51pm |
I was rather hoping not to have to strip out the glove box, I know what a mission it is!
27th Oct 2014 7:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
is your centre console ciggy lighter ignition live, some are some are not. ... - .- -.
27th Oct 2014 7:29pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
You don't have to strip the glove box out to get to the fuseboard. Just open the glovebox and then press down on the front edge and the fuseboard is there in front of you.
27th Oct 2014 7:33pm |
Stan The lighter is a perminant live from the battery, so
27th Oct 2014 7:42pm |
You drop the wire from the piggyback connector out thro the bottom of the fuseboard into the accessible space below by removing the panel and then running the cable up behind the rubber trim at the door opening to the top of the dash.
27th Oct 2014 7:52pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
What about the sunroof switch ? Not sure of amperage feed, and it is ignition fed, not acc, but could be a hell of a lot easier..... 2011 Range Rover Vogue SE 4.4 TDV8
27th Oct 2014 7:54pm |
Nicedayforit posted whilst I was typing...... Didn't mean the sunroof switch was easier than that..... 2011 Range Rover Vogue SE 4.4 TDV8
27th Oct 2014 7:56pm |
I was thinking of trying to pick up a feed from the windows, until I looked at the wiring diagram! Hadn't considered the sunroof feed, as I'm a wee bit weary about removing the pillar trim, due to airbags. Call me a scaredy cat but if it goes BANG![b] I get frighted! Yesterday I couldn't spell Engineer... Today I are one!
27th Oct 2014 8:03pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
You can get from the glovebox direct to the grill where the middle speaker is in the dash, use a straightened coat hanger or the like and poke it down through the hole after removing the grill and speaker, aim it towards the fusebox and there is quite a large hole to get it through, tape the wire to the end and carefully pull it back through... Pete
Keyhole............. is you a surgeon?
27th Oct 2014 8:08pm |
^ That's useful to know.
27th Oct 2014 8:09pm |
Apologies, for some reason, I did imagine you were mounting something near the rear view mirror, perhaps on the sunroof switch panel, hence my suggestion.
27th Oct 2014 8:11pm |
These Piggy fuse links are they commercially available or is it a bay of fleas thing? Yesterday I couldn't spell Engineer... Today I are one!
