Home > In Car Electronics (L322) > Accessory +12v Purple / White on cassette? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
27th Oct 2014 8:14pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
And Yes its going in the far right of the screen on the dash, stuck to the black bit that doesn't come out with with the cow covered bit. Personally I look over that bit when driving, might not be so good if you look through the steering wheel when driving! Yesterday I couldn't spell Engineer... Today I are one!
27th Oct 2014 8:15pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
What about the light switch or fog light feeds, that are only a few inches away ? 2011 Range Rover Vogue SE 4.4 TDV8
27th Oct 2014 8:21pm |
Ok so is fuse 7 empty, without having to brave the could to see? if so I can just plug the live feed wire into the fusebox with a lucar connector, the wire to the monitor already has a fues in it. Yesterday I couldn't spell Engineer... Today I are one!
27th Oct 2014 8:27pm |
The light switch isn't !??! its a canbus switch, I unplugged it when I had it all apart for the hands free kit and the headlights came on ?? plugged it back in and they went off ! That confused the out of me! Yesterday I couldn't spell Engineer... Today I are one!
27th Oct 2014 8:31pm |
You know I wondered that after I posted....not got RAVE handy
27th Oct 2014 8:52pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8325 |
If you just undo the bolts across the top of the dash and the ones under the speaker grille you will be able to feed a wire from the speaker to the front of the dash by the windscreen, saves taking the side bits off.... Pete
27th Oct 2014 8:56pm |
Right then you lot, WHO forgot to say that you have to remove the air vents and corner trims from the dash to remove the cow covered top
29th Oct 2014 1:13pm |
Oh no ! I did think you knew to be honest. It's in RAVE and Pete said in the post above that it saves taking the side bits off.
29th Oct 2014 1:17pm |
As mine have been in and out so many times they don't really lock now
29th Oct 2014 1:26pm |
Sorry no pictures, we've had this conversation Mark, my Box Brownie isn't computer friendly Yesterday I couldn't spell Engineer... Today I are one!
29th Oct 2014 1:32pm |
