Home > Maintenance & Mods (L322) > 2005 TD6 Alternator replacement
Rolling with laughter Rolling with laughter
It's not that bad to remove, I made a tool to do it, took all of 10mins to make and then 2 mins to get the fan off...
It's going begging if anyone wants to borrow it....
Not pretty but I wasn't going for aesthetics....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #286985 16th Oct 2014 11:48pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
On my TD6, the fan would engage in the slightest traffic queue and would then always stay on until you revved it past about 4k RPM. The woosh it made was something else, I can still remember one pedestrian (young foreign student) literally hitting the decks and adopting the brace position as he didn't know what was going on......people would literally stock in their tracks to see what approaching..... Laughing 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #286986 16th Oct 2014 11:53pm
RR2008HSE
Sounds easier than on the AJV8.
RoverV8 (D1) Alternator on top of engine at the front. Highly visible, access good. Thumbs Up
FFRR AJV8 Hidden somewhere on the back of the engine. One hour to remove ("book time"). Evil or Very Mad
This is called progress. Mr. Green
Further progress would not having to replace alternators on both Rovers in a little over a year. Big Cry
Post #286991 17th Oct 2014 1:41am
jinx1959
Scotland 2005 Range Rover Vogue Td6 Buckingham Blue
Morning guys.
I did the alternator yesterday. I had to do job outside as no room in my garage . It was wet and at times miserable.
Maybe I am just very slow but from start to finish I was nearly 5 hours. Shocked The weather didn't help having to lie in puddles to remove bottom engine cover and radiator cowling.
I used a huge shifter to remove viscous fan. It took me a wee bit to get this on the nut in a position that I could hit it with a hammer. Maybe I was lucky but one hard strike did the job. I was then able to unscrew the fan and remove radiator cowling. I then had to disconnect the twin radiator hose and top radiator hose. I used a 24mm socket attached to a long bar to release the belt tensioner. Then belt off. Then its easy to remove the alternator top bolt. The bottom bolt is covered by a pulley. You remove this with an allen key. Once that is removed you can see the alternator bottom bolt. When you loosen this bolt another pulley and a boomerang shaped bracket come away. You can then remove alternator. Mine was stuck hard so I had to use a bar to unloosen it. The next issue is getting it out the engine bay. I had to remove the large aluminium fuel cooler pipe so I could get out. Once this was done the fitting was straight forward. Everything in reverse. I have popeye arms so I find it quite difficult to get my arms and hands between cowling and viscous fan. This as a pest. I cant believe that BMW/Landrover could not have come up with a better way to design an engine. I did try to take some photographs of this procedure but having looked at them they are not worth posting. Thanks to all who gave me advice.I did look at various posts on you tube etc which although were not the same engine did give a good bit of advice. Whistle
Post #286998 17th Oct 2014 7:20am
Yep, not nice doing it in the rain... Glad you got it sorted.... Pete
Post #287013 17th Oct 2014 8:41am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Well done for struggling through the weather.
I have left the lower cover / tray off for the moment - I have a few jobs to get in there (eg new belts) and it is a pain to keep removing with so many fixings. Will be replacing before real bad weather hits. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #287016 17th Oct 2014 9:20am
