Home > Maintenance & Mods (L322) > Emergency Roof Rack (or comedy roof rack if you're a purist)
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Like dan_uk_1984 says, you want to be careful there (although with such a light load it shouldn't be an issue) - the thread in the roof is meant for clamping the foot of thr roof bar or roofrack, and is not designed for a load.
Look into the D3 forum - one of the guys managed to detach one of them from the roof somehow. Not easy to fix if it goes wrong
Post #47435 25th Jan 2011 4:05pm
I have made up some clampy down things so that the bolt tightens down onto the fixing, just to help hold things in place, and reduce the possibility of lateral movement. .
Post #47441 25th Jan 2011 5:08pm
gingerbiker
2006 Range Rover HSE Td6 Stornoway Grey
I think this is a great, quick solution to a problem; well done! I am about to start a thread which needs some inventing thinking to solve. Feel free to think of a solution for me!
Carl
Post #47524 25th Jan 2011 10:33pm
BrianC
i also think it was a great idea , it got the job done and was safe for the weight it was carrying -all this going on about load Yawn
Post #47528 25th Jan 2011 10:48pm
Back again this time with 50kg of Topper on board (and the rest inside although the top part of the mast and the boom were a bit of a squeeze). Off to sail it tomorrow Smile
Next boat will be a rib or a dory, but I'll get a trailer for that Shocked
Oh, and the first picture shows the side with the scratches on (see other post: http://www.fullfatrr.com/forum/topic6191.html) .
Post #67591 7th Jun 2011 10:41pm
good post resurrection JOE....i think its a brilliant idea for a temporary solution...
i've also seen the 'holes' on the roof used to mount a cb aerial /bracket..
edit..notice you now have different wheels , are they 18''?
Post #67614 8th Jun 2011 8:39am
Yes, put them on last autumn with new Grabbers - my winter set - just not got round to switching back to the 20"'s ! .
Post #67854 9th Jun 2011 1:26pm
Laughing ..you should leave them on , its nearly winter again....
Post #67855 9th Jun 2011 1:31pm
