Home > Photos, Videos & Media > I'm not doing this with mine
How is this possible?
Post #285144 8th Oct 2014 8:52pm
The non Land Rover product wasn't so successful.
Post #285145 8th Oct 2014 8:54pm
Welshdragon
looks soooo simple doesn't it! Thumbs Up If it dont work.......burn it!
Post #285146 8th Oct 2014 9:08pm
See the low low tyre pressures Thumbs Up .
Post #285149 8th Oct 2014 9:23pm
GrahamCharlton
England 2012 Range Rover Vogue TDV8 Stornoway Grey
He shouldn't have his arm out the window like that!
Post #285150 8th Oct 2014 9:28pm
A1GSS
Impressive. Doesn't even look like a fix, the trees are vertical in the shot... Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #285152 8th Oct 2014 9:43pm
TugRR
Something you don't want to see on the way down:
"BONG !" "HDC INACTIVE" . . . . Laughing
Thumbs Up Where do you go after one of these . . . ?
Post #285155 8th Oct 2014 10:17pm
RR2008HSE
^ Thumbs Up Bow down Rolling with laughter
Post #285158 9th Oct 2014 12:29am
mzplcg
Stop it at 1:00 and look at the 2 trees you can see. Then rotate your screen so they're vertical. That gives you a better idea of the true angle of the slope. Thumbs Up
Post #285165 9th Oct 2014 4:27am
Still a very impressive angle and its steeper at the bottom...
Post #285169 9th Oct 2014 6:24am
They're branches. Stop it at 1:08 and you can clearly see a trunk on the right that I think is a true vertical.
Post #285170 9th Oct 2014 6:40am
RiccartonRR
That's very impressive if completely un-faked Thumbs Up
A few years ago I was out checked livestock in the Defender 90 and stupidly ended up somewhere I shouldn't have. On the decent I was aware that if I touched the brakes the rear wheels would lift off the ground so I came down rather faster than anticipated Shocked That slope was no where near as steep as the one in the video but I guess the rear end of a 90 is pretty light.
Post #285171 9th Oct 2014 6:51am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
there is good traction! Cheers
James
Post #285337 9th Oct 2014 6:54pm
mzplcg
Stop it at 0:37 and check out the clumps of grass. Grass always grows vertical. Still impressive enough but the way that video has been shot would have you believe the RRS can defy gravity without a winch.
Post #285374 9th Oct 2014 8:23pm
RR2008HSE
I scared myself the same way on a VERY steep decent in my D1. I only tried it because it wasn't too long and had a nice runout. I touched the brakes and the whole back of the car suddenly felt extremely light and that it wanted to switch ends with the front! Shocked I took my feet off everything and hoped for the best. The car was great, but engine breaking in a V8 automatic made for a swift decent. Mr. Green
Post #285407 10th Oct 2014 12:46am
