![]() | Home > Photos, Videos & Media > I'm not doing this with mine |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 ![]() ![]() |
See the low low tyre pressures |
GrahamCharlton Member Since: 17 Aug 2014 Location: Newcastle upon Tyne Posts: 30 ![]() ![]() ![]() |
He shouldn't have his arm out the window like that! |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Impressive. Doesn't even look like a fix, the trees are vertical in the shot... Graham
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
Something you don't want to see on the way down:
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Stop it at 1:00 and look at the 2 trees you can see. Then rotate your screen so they're vertical. That gives you a better idea of the true angle of the slope. ![]() |
Still a very impressive angle and its steeper at the bottom... |
They're branches. Stop it at 1:08 and you can clearly see a trunk on the right that I think is a true vertical. |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
That's very impressive if completely un-faked |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 ![]() ![]() ![]() |
there is good traction! Cheers
Stop it at 0:37 and check out the clumps of grass. Grass always grows vertical. Still impressive enough but the way that video has been shot would have you believe the RRS can defy gravity without a winch. |
I scared myself the same way on a VERY steep decent in my D1. I only tried it because it wasn't too long and had a nice runout. I touched the brakes and the whole back of the car suddenly felt extremely light and that it wanted to switch ends with the front! ![]() ![]() |
