Home > Off Topic > How to cross a ditch
Rosco
I need to get a 16ton lorry across a 2ft wide 6ft deep ditch, have browsed but unable to find a solution, any help ?? Thanks Thumbs Up
Post #284874 7th Oct 2014 4:48pm
ebajema
Do you have any diggers around ?? Just fill it locally and dig it out again ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #284875 7th Oct 2014 5:00pm
Rosco
Thanks ebajema, no diggers available at the moment, a couple of what I would call tracks would be good but unable to find anything on the web, I know I am inputting the wrong description but dont know what they are called!! Thumbs Up
Post #284876 7th Oct 2014 5:05pm
Vogue
do what the military do and fill it with a quantity of logs / suitable pipes or fencing stakes on their sides, cross the ditch and then lift out 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #284878 7th Oct 2014 5:07pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Couple of Stelcon double net?
Post #284879 7th Oct 2014 5:14pm
Rosco
Thanks Vogue, the situation is I am renewing my drains and the only access to the top field is through a part which has this ditch dug, to fill it in for 1 access seems over the top so I was looking for some tracks to span it if that makes sense Thumbs Up
Post #284880 7th Oct 2014 5:15pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Rail Way Sleepers Thumbs Up
Post #284881 7th Oct 2014 5:19pm
Rosco
Good call Ken, just ordered some, will be useful anyway, thanks as I hadn't thought of that Thumbs Up
Post #284882 7th Oct 2014 5:32pm
It's Ted you want to sort out your drainage in the lower field.
Post #284883 7th Oct 2014 5:39pm
Rosco
Ahhh, unfortunately its the Top field so Ted won't do it apparently.... Thumbs Up
Post #284884 7th Oct 2014 5:42pm
Welshdragon
these do well Wink
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
There are cheaper ones on the bay of E If it dont work.......burn it!
Post #284908 7th Oct 2014 8:52pm
Rosco
Thanks welshdragon, i am trying the sleeper option as they will be useful afterwards Thumbs Up
Post #285041 8th Oct 2014 2:04pm
ken
Waffle boards as used by the Dakar Trucks are rated correctly but eye watering expensive
Remember Basics cross at 45deg so only one corner is over the ditich at the time reducing load stress Thumbs Up
Post #285048 8th Oct 2014 2:18pm
Rosco
Thanks Ken however as usual not straightforward, access is only 12Ft wide so 45 degrees would be impossible, ordered some sleepers so hopefully will work Thumbs Up
Post #285062 8th Oct 2014 3:13pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
About 30 mph
 letters not necessarily in the right order
Post #285081 8th Oct 2014 4:56pm
