![]() | Home > Off Topic > How to cross a ditch |
Do you have any diggers around ?? Just fill it locally and dig it out again ?? MY 2010 5.0 SC Galway green and sand interior!!
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2589 ![]() ![]() ![]() |
Thanks ebajema, no diggers available at the moment, a couple of what I would call tracks would be good but unable to find anything on the web, I know I am inputting the wrong description but dont know what they are called!! |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
do what the military do and fill it with a quantity of logs / suitable pipes or fencing stakes on their sides, cross the ditch and then lift out 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Couple of Stelcon double net?
Thanks Vogue, the situation is I am renewing my drains and the only access to the top field is through a part which has this ditch dug, to fill it in for 1 access seems over the top so I was looking for some tracks to span it if that makes sense |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Rail Way Sleepers |
Good call Ken, just ordered some, will be useful anyway, thanks as I hadn't thought of that |
It's Ted you want to sort out your drainage in the lower field.
Ahhh, unfortunately its the Top field so Ted won't do it apparently.... |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
these do well |
Thanks welshdragon, i am trying the sleeper option as they will be useful afterwards |
Waffle boards as used by the Dakar Trucks are rated correctly but eye watering expensive
Thanks Ken however as usual not straightforward, access is only 12Ft wide so 45 degrees would be impossible, ordered some sleepers so hopefully will work |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
About 30 mph
