Home > Off Topic > How to cross a ditch |
Do you have any diggers around ?? Just fill it locally and dig it out again ?? MY 2010 5.0 SC Galway green and sand interior!!
7th Oct 2014 4:00pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2578 |
Thanks ebajema, no diggers available at the moment, a couple of what I would call tracks would be good but unable to find anything on the web, I know I am inputting the wrong description but dont know what they are called!! |
7th Oct 2014 4:05pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3750 |
do what the military do and fill it with a quantity of logs / suitable pipes or fencing stakes on their sides, cross the ditch and then lift out 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
7th Oct 2014 4:07pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 |
Couple of Stelcon double net?
7th Oct 2014 4:14pm |
Thanks Vogue, the situation is I am renewing my drains and the only access to the top field is through a part which has this ditch dug, to fill it in for 1 access seems over the top so I was looking for some tracks to span it if that makes sense |
7th Oct 2014 4:15pm |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
Rail Way Sleepers |
7th Oct 2014 4:19pm |
Good call Ken, just ordered some, will be useful anyway, thanks as I hadn't thought of that |
7th Oct 2014 4:32pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
It's Ted you want to sort out your drainage in the lower field.
7th Oct 2014 4:39pm |
Ahhh, unfortunately its the Top field so Ted won't do it apparently.... |
7th Oct 2014 4:42pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
these do well
7th Oct 2014 7:52pm |
Thanks welshdragon, i am trying the sleeper option as they will be useful afterwards |
8th Oct 2014 1:04pm |
Waffle boards as used by the Dakar Trucks are rated correctly but eye watering expensive
8th Oct 2014 1:18pm |
Thanks Ken however as usual not straightforward, access is only 12Ft wide so 45 degrees would be impossible, ordered some sleepers so hopefully will work |
8th Oct 2014 2:13pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1097 |
About 30 mph
8th Oct 2014 3:56pm |
