![]() | Home > Wheels & Tyres > Turned Wheel Nut Help Please! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
you could use something like this,
There is some nasty "nut grabber" type socket that you can buy at tool shops and maybe Halfords. If you do a little search on the forum you will find it. The posts are about lock wheel nuts if I remember correctly.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Should it not be down to the tyre dealer to rectify the problem, at their cost! |
Binks Member Since: 03 Mar 2012 Location: Bristol Posts: 17 ![]() ![]() ![]() |
Thanks for the replies. Spoke to Duckworth who suggested a 22mm bi-hex socket - whack it on and hope! I will try that first......somewhere on here I did read that the Laser Emergency sockets do not work on these models? but thanks anyway. TDV8 3.6 2010 Santorini Black / Jet Interior
Is it the silver cap that's rotating on top of nut? If so use a grips to wiggle off the cap then remove with a 22 mm socket . Present :2008 TDV8 HSE
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
I discovered that something similar had happened to 8 of my wheel nuts. In my case an over-size socket did the job. I tend to agree that the offending tyre shop should sort this. Dan is good if you want a replacement nut. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
+1 think they should be resolving this |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
I got one off on an old car with an under size socket smashed on with a lump hammer
I have ordered a double hex 22m socket and will apply it to the offending nut with more than a little force! Googsy - what has happened is the silver cap has been turned(ie no flats left) through over-zealous torque by the tyre guys. If the silver cap comes off is there a 22mm nut beneath? Can I just cut the cap off?
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
If its a normal wheel nut (not a LOCKER!!!) then YES under the cap is a 22mm nut so just split & remove the cover and all will be well |
If the dipsticks at the tyre dealers did not realise that the silver caps were just caps and not wheel nuts then I would take the car back to them and get them to fix it, then get the prat who did it sacked! |
If it only the silver cap turning panic over I only replaced 4 such blighters this very day due to them swelling. I use a grips with a clamp on the silver cap to manipulate and pull off it's quite easy. Yes under the cap is a 22 mm |
Fair enough about the wheel nut caps, but if the tyre dealers (presumably so called 'specialists'), my point is that if they do not realise that they are bolloxing up wheel nut covers what the f**k are they doing employed as tyre fitters |
Because most are "Monkeys" paid "peanuts" |
