Home > Technical (L322) > Newbie on here with a gearbox issue |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
What tyres do you have on them? |
15th Sep 2014 11:14am |
Richards7 Member Since: 15 Sep 2014 Location: Cumbria Posts: 8 |
on the overfinch ones it has 3 toyo proxes 285/35/22 ( I think thats the size as I'm not near the car right now). the fourth is a same size tyre of onknown make, possibly chinese as it was bought in a rush following a puncture. Another thing confusing me is that I have in the past popped on one of the 19 inch originals on in lieu of a spare |
15th Sep 2014 11:29am |
I would be very very surprised that the wheels would have anything to do with the gearbox issues even though it goes away when you are rolling on 19 inchers. I wonder if it makes a difference if the CCF file is updated with the correct wheels !! MY 2010 5.0 SC Galway green and sand interior!!
15th Sep 2014 12:06pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
The transmission controller has a ‘curve recognition mode’ which is designed to inhibit upshifts while the vehicle is cornering (for stability) and it kicks in if there’s a speed difference detected of more than 1 km/h between the front wheels. If you have the odd tyre on the front it might be worth swapping it to the rear?
15th Sep 2014 12:11pm |
Hmm... Yes the odd tyre although the same size was on the front. I will try to sort this weekend and let you know |
15th Sep 2014 1:24pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2266 |
Brilliant bit of info Ta for that |
15th Sep 2014 4:11pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Is that on all model years or just the later ones ?
15th Sep 2014 5:41pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
If you want to look after your transmission never run with different tyres and / or large differences of tread on the same axle and if you can help it try and keep it all "same" on all four corners.
15th Sep 2014 8:10pm |
