![]() | Home > Technical (L322) > Ultimate infotainment upgrade |
Ugghhh. I knew there was a reason there are so many new screens floating around ebay for not much... None of that for me then. Too much work. Can't be letting Colin have all the fun though. Here's a couple of pics of my upgrade. As mine too was an MID (non Nav) vehicle, before adding the PC/touch screen/etc, I first had to make the base system work. This meant installing wiring and components for the OEM I-Bus nav + the wiring for the future (pc) components. Even with the older system, buying new components/wiring was prohibitively expensive so my purchasing went the same way Colin's did: internet, a friendly dealer, and the bay. Finding the components was not difficult but Range Rover harnesses are generally not available. Since the systems were standardized by BMW and I was going to be adding wiring anyway, the easiest and least expensive route was to pick up a BMW harness and modify it to fit the RR and suit my needs. I got a harness from an E46 with DSP - so better sound and a sub were added into the overall picture as well. First thing to do was to trial fit the harness to determine where it needed to be modified. So the RR came apart and in went all the components. ![]() ![]() I do have to say that I was just as impressed on dissecting the RR as when first driving an LM. I worked on cars (mainly MB, BMW, and Porsche) professionally for about 12 years while going to high school and university. I've taken apart a lot of vehicles (including Rolls and Bentley). None were like the LM. The fit of the interior parts is impeccable. Most impressive, though, is the weight of the pieces. Even the smallest cover has dampening material on the back - and I thought I was going to keel over when lifting out the back seat. Unreal. It is no wonder driving an LM is so supple. ![]() Here's the harness in mid work with tags noting what needed to be done. ![]() Despite the very different sizes of the vehicles, there was surprisingly little that needed to be changed. After about 3 1/2 hrs of work the harness was done including the addition of USB and several addtl shielded cables front to rear. So then it was off to the car to see if everything worked before burying the harness. ![]() ![]() ![]() So today I have to button everything back up. Items that remain to be done in the future are: - recoding the nav computer - modifying my second head unit for touch screen - configuring the PC - still a lot to decide on - finishing the phone integration in the consloe - possibly reworking the MY10 steering wheel switches. These are actually the more time consuming tasks, though... :cry: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 ![]() ![]() ![]() |
Very very nice Steve, you really are a man after my own heart |
Yeah, it works. That was the reason for the smiley following the 2 shots of the monitor (full sunlight - hard to take pics of a monitor). I did have trouble with a dodgy connector/cable to the GPS antenna - but that was BMW not me. |
Well chaps
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi colin, looks like its going well, how did you get on with the steering wheel controls, could i ask you for the part number for the module that talk to the can bus and ibus you mentioned before..i wanted to try and start locating one...
Hiya Daveo
3R10 Member Since: 17 Oct 2009 Location: Paris Posts: 324 ![]() ![]() |
This BBS SPY guy is a real genius! |
hi Colin, that's the one...i was blinded by the excitement of your site and the possibility of adding more bits, that's what you call a proper project. i have a full set off the 2009/10 cameras with the module, 2x mirror cams front and rear bumper cam if any use to you but i think you have already said they are on the new can bus system but the offer is there..when you get round to doing the vc i would like to know if it needs the cam bus connected to show any signs of life as i wired my one up as to the pin out 12v + and ground but it still showed no signs of life, didn't charge the cam unit..
Hiya all
hi Colin, sounds good, did it need a signal from the can bus or the monitor as when i connected my one with 12v and neg it still had no signs of life, i thought it would at least charge the camera...i am waiting to hear if he finds the gateway unit..just of to have an update on your site..
Hiya Daveo
hi colin just thought, i have a v/c mount trim in that dark blue.... is your dash trim dark blue
I thought they were all black, send me a piccy or give me a part number. |
Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23 ![]() ![]() ![]() |
Colin - I've read this very interesting thread in some detail, and see that you are planning to fit a reversing camera as part of your installation. Please can you answer me a couple of simple questions - I also want to fit a reversing camera to my 2005 L322. I have a really good quality, wide field of view, low light camera, I want to connect it to my (Denso) touch screen head unit.
