[quote="BBS SPY"]Well that is part of the Gateway ECU's purporse daveo, and of course what i am clearly using as the base of this entire project as i have previously stated
Without LR producing it as a temporary solution in 2005 only, just so they could add their own infotainment stuff i would not be able to do this project at all.
The gateway effectively taps into the BMW private CAN bus to get all the info it needs for Ign state, current Gear, Road speed, EAS and steering angle. It also taps into the Ibus for the steering wheel controls, clock sync and other stuff.
Then on the output side it provides the Low or Medium speed CAN bus with all the info on it as well as a CCF that the various later systems require, including the Venture Dock. This CAN bus is also connected to the Diagnostic socket and it is over this that the Gateway CCF is configured and access to the IHU and thus the MOST bus systems plugged into it is made.
I am not sure you could run the Gateway ECU without the Head unit, but then there would not be much point to that as you need the Head unit to provide the MOST bus and the screen to see the output of the Venture cams anyway.quote]
Hi again,
I am fitting the Venture cam into the D3 currently, operating in FFRR mode on the touchscreen,
could you advise the colours of the can bus I need to tie into to get the control signals to the docking station, I see pin 1 is negitive and pin 4 is 12v positive.
can you confirm the pins orentation for the can bus?
thank Rob Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
