Home > Technical (L322) > Select Neutral?
philrover
2006 Range Rover HSE 4.4 V8 Chawton White
Select Neutral?
In the past couples of days, each time i start the car i get a message saying "select neutral", then the moment i drive off it will say "slow down". Then it goes away. Im thinking this message appears when the engine is running hot, but my temp is dead center and no signs of overheating. What could be causing this? BTW this is a 2003 FFRR 4.4V8. 06 FFRR HSE
04 Freelander SE3 V6
97 Defender 110 300tdi
01 BMW 523i Touring
97 RR 4.6HSE
Post #24682 5th Aug 2010 10:42am
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Re: Select Neutral?
Not sure if will help your prob but try putting vehicle in tow mode by removing the fuse etc then taking it out of toe mode see if that helps, Ive had this come up on me a few times on my 04 V8 // ...
Post #24684 5th Aug 2010 10:59am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
On my 2006, you get this message when you have flicked the "low range" switch - it's asking you to select neutral and then it will switch into low range for you. If you flick the "low range" switch again, the message goes away ...
Post #24695 5th Aug 2010 12:39pm
daveo
same here, i get that message when in low range, the neutral part is you have to select it to switch between low and high range, V8 facelift Range Rover Autobiography 22" wheels.
Post #24724 5th Aug 2010 3:58pm
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
I have exactly the same behaviour since I unplugged all fuses (to locate battery drain) a few days ago.
How did it end up for you? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #178032 17th Mar 2013 3:49pm
Normally means the hi low motor is defective! £1350+vat ouch!!!
Post #178091 17th Mar 2013 7:19pm
Ibartsimp
Can fuse removal provoque this issue (I mean killing the motor). 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #178092 17th Mar 2013 7:26pm
That's spoilt a few Sunday evenings. Laughing
Post #178093 17th Mar 2013 7:28pm
A problem we are seeing more and more im afraid, the motor is not in high or low range completely hence the prompts on the dash... Sad
Post #178127 17th Mar 2013 11:39pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
There is a thread on here somewhere about replacing the rheostat / circular resistor component within the tranfer motor. It was not a part that was available through land rover, but a member was getting some manufactured and was planning to sell them at a fraction of the quoted price for the full motor. I do not know the outcome, but it could be worth doing some digging to find the thread and see if he ever did get some manufactured. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #178699 20th Mar 2013 6:48pm
No still not manufactured/available, but apparently still coming..... .
Post #178700 20th Mar 2013 6:50pm
woodchopper23
Post #178705 20th Mar 2013 6:56pm
GraemeC
From reading a bunch of threads on this subject, it seems a regular cycle between Hi and Low ratio is a good habit to get into - IIRC the problem with the rheostat is corrosion/fusing due to lack of movement! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #178746 20th Mar 2013 8:03pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Mine did this when turning a left hand corner as one of the abs sensors was bust , the difference in wheel speedsmade the car think something was up and would try put thebox into low range.the new abs sensor cured it.
Post #181586 6th Apr 2013 8:43pm
Johnte
Do you mean one of these? Could be a good buy Thumbs Up
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...2ec760e98a
Post #181797 8th Apr 2013 9:00am
