Home > Technical (L322) > pressure static when filling |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35427 |
did mine earlier and from access to standard and then standard to off road was about 18 seconds...
12th Aug 2014 12:04pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Cheers Stan, 18 seconds is quick, if other FF's are that quick from access to off road height, i'd be looking to rebuild compressor. If it dont work.......burn it!
12th Aug 2014 1:13pm |
surprised me as well but mines a 2009my so some obvious improvements have been made to the 'air' bits. ... - .- -.
12th Aug 2014 2:41pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
20 secs on mine GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
12th Aug 2014 3:13pm |
Thanks Paul, that's quick too.
13th Aug 2014 9:44am |
mine is defo different to the td6 compressor..craig was going to replace my exhaust filter [see pic] but found mine is twice the bore size of the standard filter...also my td6 had a small tank underneath the off side rear where as the one a have now is a larger [3 times the size?] full length jobby..
13th Aug 2014 10:55am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Can't test mine at the moment as I have it locked out in Motorway mode and doing a how long will it last before I get the AIR SUSP INACTIVE fault Been 2 days / 90 miles so far on six starts. (I have the same issue as Welsh Dragon)
13th Aug 2014 5:15pm |
I had a quick look at it yesterday, it looks a pig of a job to get to, easy enough to change but that tank cover needs to come off first, or at least wedge it out of the way just to get a spanner on it, so I will be waiting a clear day, not raining and attack it ...
13th Aug 2014 5:42pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
Just did mine for you... 2002 4.4 Vogue
13th Aug 2014 6:53pm |
Oh yes thats helped much thanks
13th Aug 2014 7:14pm |
Just an up date on this, I changed the pressure switch and cleared the eas faults only (21st August), the message came back24 hours later!. So I cleared ALL messages on the FF ecu's and so far for the last week an a bit she has behaved so far
31st Aug 2014 11:21am |
Just swapped out my pressure switch
6th Sep 2014 11:20am |
6th Sep 2014 4:00pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
@Joe 90
6th Sep 2014 4:55pm |
