Home > Technical (L322) > pressure static when filling
Page 1 of 4 1234>
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
This is well documented on many forums but before I spend time and brass on the FF I have a favour to all who have the IId tool.
I just would like to know what other FF do
Could you set the RR to access height then raise to off road height and time it, look at what reservoir psi is before, during and when compressor stopped, also temp.
I'm not convinced the compressor is Censored yet as this is what I get, is it normal or to long to raise?
From access height to off road height timed as 1 min 26 seconds ( steady light from access to off road ), reservoir was at 188psi at the start of raising, compressor filling reservoir at 152 when rising the RR up. Compressor stops at 189/188psi and temp at 78deg c
So I have faults codes 57 in the lcm and code 74 in the eas, happened either once a week or 2 in a day, very intermittent fault easy enough to reset, but every time when switching off the RR the message shows up, next time I start the RR up its gone!
I have also bypassed the PRV so I know its not that.
I have checked for leaks and connector, all seem good, I more convinced its the pressure switch on the back of reservoir but I could be wrong Confused
If she don't get fixed soon it'll go as Mrs Dragon don't like the FF and wanted a land Cruiser, we had one for towing and it NEVER gave a problem, sold her with 225000 ish miles! If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #275441 12th Aug 2014 9:37am
did mine earlier and from access to standard and then standard to off road was about 18 seconds...
but i'm sure i have a different compressor with a larger tank under the off side of the FF.. ... - .- -.
Post #275462 12th Aug 2014 12:04pm
Welshdragon
Cheers Stan, 18 seconds is quick, if other FF's are that quick from access to off road height, i'd be looking to rebuild compressor. If it dont work.......burn it!
Post #275467 12th Aug 2014 1:13pm
surprised me as well but mines a 2009my so some obvious improvements have been made to the 'air' bits. ... - .- -.
Post #275477 12th Aug 2014 2:41pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
20 secs on mine Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #275491 12th Aug 2014 3:13pm
Welshdragon
Thanks Paul, that's quick too.
what is the obvious differences to the compressor? bigger piston size/ chamber?
Is there anyone with a pre face life who could try this out.
If both of yours Stan and Paul are under the 30 sec mark looks as if it is the compressor at fault on mine. If it dont work.......burn it!
Post #275605 13th Aug 2014 9:44am
mine is defo different to the td6 compressor..craig was going to replace my exhaust filter [see pic] but found mine is twice the bore size of the standard filter...also my td6 had a small tank underneath the off side rear where as the one a have now is a larger [3 times the size?] full length jobby..
it does sound like yours could do with a refurb if its taking that long to blow up..
standard exhaust filter,
Post #275619 13th Aug 2014 10:55am
Can't test mine at the moment as I have it locked out in Motorway mode and doing a how long will it last before I get the AIR SUSP INACTIVE fault Twisted Evil Been 2 days / 90 miles so far on six starts. (I have the same issue as Welsh Dragon) Laughing
But from experience between 1 and 2 minutes, even after fitting Jockstrap (sorry) Bagpipe Andy's ring in my pump Shocked
When are you fitting the new sensor and telling me you have fixed it MIke? .
Post #275681 13th Aug 2014 5:15pm
Welshdragon
I had a quick look at it yesterday, it looks a pig of a job to get to, easy enough to change but that tank cover needs to come off first, or at least wedge it out of the way just to get a spanner on it, so I will be waiting a clear day, not raining and attack it ... Laughing Thumbs Up
Its going to be one or two things this problem, will keep you posted. If it dont work.......burn it!
Post #275685 13th Aug 2014 5:42pm
Just did mine for you... 2002 4.4 Vogue
Started engine and compressor topped up tank straight away
Comp temp 39deg
Dropped to access, (been playing with mine and the access height is lower than stock, 425mm center of wheel to top of wheelarch, front wheel)
Comp pressure 188psi
Switched it to off road height (again been playing, mine is higher than stock at 555mm)
Comp psi dropped to 143 at it's lowest but sat at 152 for most of the raising
Took 1.51 min to raise to offroad
Comp temp peaked at 92deg, dropped to 60deg after about 3mins.
total height raised 135mm, just over 5inches
My pump has had a recent new piston ring and the dryer has been baked, it sits where the tow bar cubby hole is as mines on LPG...
Hope that lot helps... Pete
Post #275696 13th Aug 2014 6:53pm
Welshdragon
Oh yes thats helped much thanks Bow down Thumbs Up
Temp on compressor and when filling up when raising to off road hight is about same as mine, time will be different as yours is lower and higher, but not by much though.
Im going to change the pressure switch first to eleminate that and see what that brings up, or not as the case may be. If it dont work.......burn it!
Post #275697 13th Aug 2014 7:14pm
Welshdragon
Just an up date on this, I changed the pressure switch and cleared the eas faults only (21st August), the message came back24 hours later!. So I cleared ALL messages on the FF ecu's and so far for the last week an a bit she has behaved so far Thumbs Up
One thing to check before changing the switch is how tight it is fitted to the reservoir and if there is any corrosion/ pitting in the recess as that might be a place for leaks in the system, mine was in all honesty finger tight on Shocked
Hope this helps anyone else with the static when filling problem. If it dont work.......burn it!
Post #278301 31st Aug 2014 11:21am
Just swapped out my pressure switch Smile
45 minutes job.
Tip: undoing all the tank cover bolts along the sill, facing forwards, and beside the exhaust will allow the tank cover to drop sufficiently to access the switch, not need to undo the two at the back under the rear subframe.
Pressure switch is 24mm a bit tight in situ to get a socket on it, but my big adjustable worked OK. Seems the switch tightens up flush to its inner seat, so only needs to be spanner "hand tight".
Now we wait...... .
Post #279417 6th Sep 2014 11:20am
Welshdragon
Hope it works mate, fingers crossed for ya it does the trick Thumbs Up
Or you might have to revert too my motto below! Laughing If it dont work.......burn it!
Post #279448 6th Sep 2014 4:00pm
@Joe 90
Given the pressure the air tank stores air at I would have expected some sort of thread sealant on the threads of the pressure switch, be it goo or ptfe tape.
The threads can't be air-tight at those sort of pressures unless of course there is a sealing ring on the switch.
Just an observation. Thumbs Up
Post #279458 6th Sep 2014 4:55pm
Page 1 of 4 1234>
