Home > Technical (L322) > pressure static when filling |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
@ nicedayforit
6th Sep 2014 5:00pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Nicedayforit, my pressure switch was clean on the thread as well, as the switch has a rubber O ring and the switch fits in the tank recess, when tighten up is wont leak air. If it dont work.......burn it!
6th Sep 2014 8:02pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Thought it must be sealed somehow. |
6th Sep 2014 9:12pm |
Sadly, not fixed for me. Made it @ 6 miles from home this morning before faulting. Same fault, so haven't moved the problem
8th Sep 2014 7:22am |
8th Sep 2014 7:36am |
Yes .
8th Sep 2014 10:44am |
8th Sep 2014 12:01pm |
Not wanting to count chickens but have now been 2 + 1/2 days fault free (6 journeys @ 100 miles in total) since I reset (all ecus) Monday morning. Pretty certain I did the same after fitting the new sensor but at my age.....
10th Sep 2014 5:39pm |
Fingers crossed for ya mate If it dont work.......burn it!
10th Sep 2014 6:26pm |
B ks
11th Sep 2014 7:19am |
oh
11th Sep 2014 11:42am |
Compressor coming out on the bench tomorrow, see if I can find the reed valve Haylands mentioned. Will also pull it apart a bit to see what else I can find. Having done bagpipe andy's repair only recently am guessing my piston broke (gag) .
12th Sep 2014 4:45pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
Hopefully be the read valve Joe, can't see it would be much else, unless the piston ring has broken....
12th Sep 2014 6:13pm |
Should have done all this when I had it out last time
12th Sep 2014 10:32pm |
