Home > Maintenance & Mods (L322) > Nutty prices - swollen nuts |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Well, following on from my quest to eradicate squealing from the front wheels:
24th Jun 2014 2:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
i doubt if that would cause a squeal ryan, single nuts are available from ebay/powerfuluk
24th Jun 2014 2:29pm |
Thank you Stan... I've just ordered a new pair of nuts |
24th Jun 2014 5:24pm |
first you had a screw loose and now you're nuts.... ... - .- -.
24th Jun 2014 7:07pm |
Using this search description just ordered a set of 5 for £15.70 including free delivery by Wednesday:
6th Dec 2015 7:02pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
Should you find said squeak please advise as yours sounds identical to mine even to the location and it's the worst sort, intermittent.
6th Dec 2015 7:52pm |
Apologies Paul, I actually resurrected this thread on the subject of swollen nuts. We no longer have the RR that the squeak related to and don't want to dishearten but the overwhelming feeling from professionals at the time was that the squeak was connected to the front brake pads I had fitted which were not LR but Brembo pads (in fairness the squeak wasn't there with the previous LR pads).
6th Dec 2015 8:46pm |
Ah ok thanks anyway.
6th Dec 2015 8:56pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
http://www.advancedfactors.co.uk/rrd500510...5929-p.asp Visiting from DISCO3.CO.UK
7th Dec 2015 8:52am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
When you say new genuine Brembo pads... Purchased from where sir? |
7th Dec 2015 9:12am |
Hi Craig, supplied and fitted by my good friend Chris Mullens tyres here in Gloucester, £115 all in from memory. Many thanks
7th Dec 2015 4:12pm |
Pv... Craig has previously queried references to 'Brembo' pads... A la Brembo don't actually make pads
7th Dec 2015 4:47pm |
I was offered std or genuine Brembo and have 100% trust that that's what I received.
7th Dec 2015 4:54pm |
It seems to be a source of debate. Can you or can you not get 'Brembo' pads. |
7th Dec 2015 8:12pm |
