Home > Maintenance & Mods (L322) > Nutty prices - swollen nuts
pld118
Well, following on from my quest to eradicate squealing from the front wheels:
http://www.fullfatrr.com/forum/topic26089.html
Today I removed the front passenger wheel which has seemed to be the main culprit. I could see nothing obvious like a trapped stone or visibly knackered components and whilst awaiting a recall from a mechanic who will hopefully do some brake stripping, cleaning and greasing, I decided to properly clean the visible parts (disc face, hub, caliper, fully cleaned the insides of the removed alloy etc).
And so, when putting the wheel back on, I found that one of the nuts (visibly in very good condition) did not want to go back on and it took a good 30 minutes before I could find a technique to re-thread it without forcing it, which got me wondering/ hoping, could that be the culprit for the wheel squeal?
Probably not but the main thing is no damage has been caused, although someone could easily (maybe has in the past) been tempted to force it back on which could cause all sorts of problems.
Wheels are the original facelift 4.2 SC 9 spoke wheels. Can the nuts be bought individually does anyone know as it's the only one that doesn't like going on?
Thanks
Post #267101 24th Jun 2014 2:03pm
i doubt if that would cause a squeal ryan, single nuts are available from ebay/powerfuluk
http://www.ebay.co.uk/itm/Single-Wheel-nut...ange+Rover ... - .- -.
Post #267104 24th Jun 2014 2:29pm
pld118
Thank you Stan... I've just ordered a new pair of nuts Mr. Green
Post #267126 24th Jun 2014 5:24pm
first you had a screw loose and now you're nuts.... Rolling with laughter ... - .- -.
Post #267140 24th Jun 2014 7:07pm
pld118
That's nuts!
Eh, just went to order some nuts and when looking back at having bought some from Powerful UK in June 2014 for £3.49 each, to buy single nuts now are listing at £9 each Shocked
Post #360719 6th Dec 2015 6:47pm
pld118
Using this search description just ordered a set of 5 for £15.70 including free delivery by Wednesday:
Range Rover L322 (06 On) Stainless Capped Alloy Wheel Nut x5 - Bearmach Parts
Will do for me! Thumbs Up
Post #360724 6th Dec 2015 7:02pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Should you find said squeak please advise as yours sounds identical to mine even to the location and it's the worst sort, intermittent.
Brakes stripped and cleaned, new genuine Brembo pads fitted, locking wheel nut ( all binned and replaced with new plain nuts) yet found nothing.
When it does squeak it can get loud and the lightest brake pressure stops it so feel it has to be that area but can't find anything. Many thanks
Paul
Post #360738 6th Dec 2015 7:52pm
pld118
Apologies Paul, I actually resurrected this thread on the subject of swollen nuts. We no longer have the RR that the squeak related to and don't want to dishearten but the overwhelming feeling from professionals at the time was that the squeak was connected to the front brake pads I had fitted which were not LR but Brembo pads (in fairness the squeak wasn't there with the previous LR pads).
Post #360751 6th Dec 2015 8:46pm
Pvw10
Ah ok thanks anyway.
Any other interested parties, I changed the pads as thought there may be marked etc but with the new Brembo pads and a full brake service there was no change.
Then I was heard to shout aaaaaaaaaaaarrrrrrrrrrrggggggggghhhhhhh followed by some fluent French 😃 Many thanks
Paul
Post #360756 6th Dec 2015 8:56pm
Lost for Words
http://www.advancedfactors.co.uk/rrd500510...5929-p.asp Wink Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #360824 7th Dec 2015 8:52am
When you say new genuine Brembo pads... Purchased from where sir?
Post #360829 7th Dec 2015 9:12am
Pvw10
Hi Craig, supplied and fitted by my good friend Chris Mullens tyres here in Gloucester, £115 all in from memory. Many thanks
Paul
Post #360879 7th Dec 2015 4:12pm
pld118
Pv... Craig has previously queried references to 'Brembo' pads... A la Brembo don't actually make pads Thumbs Up
http://www.fullfatrr.com/forum/topic23290.html?highlight=brembo
Post #360885 7th Dec 2015 4:47pm
Pvw10
I was offered std or genuine Brembo and have 100% trust that that's what I received.
Even if there just Brembo branded I don't care as if there good enough to put there name to them then that's good enough for me. Many thanks
Paul
Post #360887 7th Dec 2015 4:54pm
pld118
It seems to be a source of debate. Can you or can you not get 'Brembo' pads.
Post #360930 7th Dec 2015 8:12pm
