Home > Technical (L322) > Double glazing??
miggit
Laminated glass has it's advantages and disadvantages, Advantages include better sound insulation and security, down side is if you have to get out after a woopsy, you can't smash the glass and climb out. As far as strength goes, toughened glass is a lot stronger, and harder to brake Very Happy , but once it's broken it will disintegrate in to thousands of tiny bits Sad . Where as the laminated will crack a lot easier but will stay together in one piece. Yesterday I couldn't spell Engineer... Today I are one!
Post #343205 18th Aug 2015 11:58pm
2011> models have it all around Thumbs Up
Post #343208 19th Aug 2015 12:42am
apole
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Not checked if my 08 has this yet.
My audi does, they call it double pane glass, reduces noise. However I have seen some older ones start to mist at the corners, presumably due to the laminate breaking down.
Post #343574 21st Aug 2015 10:51am
Should be fronts only on an 08 i think sir Thumbs Up
Post #343702 21st Aug 2015 11:49pm
johnboyairey
Those old S class 'Diana' Mercs defo had double glazing, sort of sealed units.
Aparently, when you took the option, a guy would come round your house, and talk about the benefits, and would not leave until you signed up for the double glazing, after halving the original bill, then the receptionist would ring you later in the week, and give you a 'one day' deal price.
Post #343871 23rd Aug 2015 12:15am
