Home > Technical (L322) > Double glazing??
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Double glazing??
I didn't notice this type of glass on any of my previous range rovers. It appears to be two peices of glass with a laminate in the middle. It's only like this on the front???
Does anyone else have glass like this? Is it just on the 2007 onwards ones?
 My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #23234 26th Jul 2010 6:36pm
Fox
My November 05 facelift has the same.
Post #23236 26th Jul 2010 6:40pm
daveo
as you said, its laminated..the other type would be toughened glass, my self i would rather the laminated,it stays togeater when or if cracked like a windscreen. V8 facelift Range Rover Autobiography 22" wheels.
Post #23237 26th Jul 2010 6:56pm
yeah got it on mine 05 facelift SC
Post #23249 26th Jul 2010 7:53pm
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
My 07MY has the Double Glazing too Thumbs Up If you have nothing nice to say,say nothing at all.
Post #23277 26th Jul 2010 10:35pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
It is laminated front (and possibly rear too) side windows that was introduced in the 06 MY vehicles to reduce cabin noise. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #23287 27th Jul 2010 2:29am
Andy
A nice upgrade if the side windows should ever need replacing! Thumbs Up 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #23733 30th Jul 2010 3:21pm
Yeah its just laminated glass, the downside being that when I got someone in to pull out a couple of dings on my last L322, one was in the door and he would have 'gone in' via the window glass area but wouldn't touch it because he said the glass has a tendency to shatter into a million pieces. Discovery 4 HSE
Post #23761 30th Jul 2010 6:47pm
daveo
the laminated would just crack like a windsheeld, the toughened glass will shatter into thousends of bits V8 facelift Range Rover Autobiography 22" wheels.
Post #23776 30th Jul 2010 9:20pm
dan_uk_1984
I thought this - however I think it's thicker glass and wont fit in the door Big Cry
Post #23778 30th Jul 2010 9:53pm
I must have it the wrong way round then!
Surely for security purposes, it would be better if the side glass was laminated? Discovery 4 HSE
Post #23791 31st Jul 2010 8:44am
hoppy_70
If your old one was pre 2006 then that would be toughned which turns to beads when broken. Your current one should be laminated.
I bet it would fit on the earlier car too, it's not much thicker than the old glass. I have noticed a noise reduction since my 2005 car. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #23798 31st Jul 2010 9:39am
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Is it normal that my front windows are double glazed but the rears not?
If i remember right my fathers allroad had double glazing all around.
Post #343145 18th Aug 2015 7:02pm
marky777
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Bonatti Grey
Mine are the laminated type 05 facelift se/ab
Post #343149 18th Aug 2015 7:08pm
dan_uk_1984
None are "Double Glazed"
The fronts are two pieces laminated together - there is no air gap. The lamination increases strength, but the main reason was to cut down on outside noise.
Post #343151 18th Aug 2015 7:16pm
