![]() | Home > Technical (L322) > Hi/low box motor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
there's something akin to this in the wiki.. ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Well done rejo, I have the same problem as you (have had for years) and not been able to resolve the reason why it won't go back up into high. I resorted to using a knackered old motor which I dismantled, bolted on and span the motor spinlde to wind the thing back up into high. I even have a new motor (wrapped up nice and warm in the garage) which didn't fix things.
rejo Member Since: 10 Feb 2013 Location: Netherlands Posts: 28 ![]() |
Yes thats true, but that doesn't get the gearbox back into high.
What doesn't get it back to high? .
If you power the motor up while it's on the car this will move the box back to high or to low depending on what you want. |
Ok, it seems as though I still have a problem somewhere.!
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I had a situation in my TD6 where the transfer shift motor was playing up so it was disconnected. The gearbox was physically in high but the engine ECU thought it was in low and the driving behaviour was odd! It would change at 3000 RPM even in kick down. As soon as I plugged the TSM connector back on, the gearbox went straight back to low and there it stayed.
ok, thanks SKOT for the reply, any idea on how to unconfuse the ECU ? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
I should check what range the shift motor is telling the ECU it’s in. The resistance between pins 1 & 2 should be around 4.7 kilohms in high range and 1.6 kilohms in low range.
Hi rrphil
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
on the subject of your headlight wiper the drivers side one ,or passenger side if your car is a normal one in the uk.
