Home > General (L405) > Knocking Update |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
hope this sorts it Neil.. ... - .- -.
4th Jun 2014 12:50pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Will this incur a recall for all l405 cars with active suspension or is it just a certain percentage affected? Agueroooooooooo. 93-20
4th Jun 2014 5:28pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Hope it's the end of it for you.
4th Jun 2014 5:37pm |
Imagine having to change all of the above on every 405 that has left the factory!! |
4th Jun 2014 5:39pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
It will be interesting to see how this pans out. |
4th Jun 2014 5:43pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Or pussy out like most companies and only replace when people complain. |
4th Jun 2014 6:45pm |
CaptainG Member Since: 16 Dec 2013 Location: Bristol Posts: 13 |
Hi 5.0, just wondered if you have had this latest update fitted yet and if so how its going so far? |
18th Jun 2014 10:48am |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 |
It is in the workshop now being done. I will post here the result when I get it back. However time will only tell if it is a permanent fix because, as others have posted, the noise comes back after a few hundred miles for any ARC bar changes which have been done previously. It remains to be seen if the new valve block is the answer to the problem. |
18th Jun 2014 10:57am |
Well it's back and the knocking has gone. Let's see if it lasts. I shall be racking up some miles on a holiday to the West Country in the next week or so. If it comes back from that silent I shall be a happy man. The combination of no knocking and no diesel makes for such a nice quiet drive compared to the loaner I have been knocking about in (pun intented) the last couple of days
19th Jun 2014 4:43pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Good luck! |
19th Jun 2014 7:37pm |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 |
5.0, when you mention the information from the technician regarding the two dampers on the ARC, are these a completely new addition?
21st Jun 2014 9:05pm |
Doodle, yes, valve block dampers and software all new.
22nd Jun 2014 5:21pm |
RR-5.0SC Member Since: 25 Jun 2014 Location: Leeds Posts: 3 |
hi 5.0, I also have this issue how is the latest fix holding out still no knocking |
25th Jun 2014 11:29pm |
Nothing more to add to my previous post at the moment. I will testing it out on holiday next week and will let you know how it does. |
26th Jun 2014 3:29pm |
