Home > General (L405) > radio regional change help needed.
buflanfx45
Qatar 2013 Range Rover 5.0 SC V8 Santorini Black
good morning Gentelmen,
I own a 2013 Range rover which i have bought from USA and i have shipped it to QATAR. does any one know how i can change the regional setting o the radio so i can pick up even number frequencies.
at the moment the frequencies are : 90.7 to 90.9. i would like to get 90.8
please let me know
Post #261793 28th May 2014 4:10am
i suspect you would have to replace the tuner with an european one to get the even numbers.. ... - .- -.
Post #261813 28th May 2014 8:22am
buflanfx45
Thank you stan for the reply. But would the dealer be able to replace only the tuner?
On RR sport 2012 it was a matter of changing the market code from usa to ec or jpn and so on . Why cant we do same here.
Post #261835 28th May 2014 10:35am
i'd have a word with a dealer and ask if this code change is possible, i'm sure you're not the first to import a car in this situation.. ... - .- -.
Post #261839 28th May 2014 10:56am
mzplcg
USA spec and European spec radio FM tuners are different. I recall this in the days when the Nakamichi TD1200 was only available with a USA spec tuner. Fine if you give it a strong signal and it's on a frequency you can select but generally speaking a US tuner outside of the USA is about as much use as tits on a bull. It has to be changed for a regionally correct one.
Post #261842 28th May 2014 11:22am
buflanfx45
Thank you for the reply. Just for the sake of discussion this was not the case with bmw. I had 2011 x6 imported from usa and i have found a person that does re coding for the software and changed the regional setting and it was all good. In addition i have seen a thread in this forum to do this chane for RR sport 2012.
Post #261844 28th May 2014 12:16pm
the old sport probably uses a completely different firmware system than the very new l405 ...asking the dealer is the first step.. ... - .- -.
Post #261848 28th May 2014 12:31pm
ebajema
Maybe contact Steve of Gap Diagnostics. He may know and their IID tool may have the functionality built in to change the region and therefore hopefully the tuner settings Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #261852 28th May 2014 12:43pm
i have already looked on the GAP site and there isnt a l405 listed [yet Wink ] ... - .- -.
Post #261863 28th May 2014 1:34pm
buflanfx45
I am out of luck, GAP had replied to me that they can not do anything now but maybe end 2014.
I am trying with th edealer if they would change the tuner only which i doubt..
only if i have a blue print of thier circut board then i can replace the voltage steper on it .
thank you all for the replies.
Post #262017 29th May 2014 4:31am
doesnt yours have dab ?.. ... - .- -.
Post #262025 29th May 2014 6:27am
ebajema
Faultmate (Blackbox Solutions) does have the L405 software already but their systems are a lot more expensive than the IID Tool. I have a Faultmate Xtreme because I didn't know about the IID tool at the time. MY 2010 5.0 SC Galway green and sand interior!!
Post #262026 29th May 2014 6:37am
buflanfx45
what is DAP??
i have sent an email to black box solution and waiting for the reply.
thank you gentelmen.
Post #262054 29th May 2014 8:31am
Digital Audio Broadcasting ... - .- -.
Post #262064 29th May 2014 9:02am
can you not enter the frequency manually and save as a pre-set?
FM Stations
90.8 – QBS Arabic
92.0 – MBC
92.6 – Radio Sawa Gulf
93.7 – QF Radio
94.0 – Oryx FM French
94.6 – Bahrain FM
97.5 – QBS English/French
99.6 – Radio Monte Carlo
100.8 – Sout Al Khaleej
101.7 – Al Jazeera English
103.4 – Quran Kareem Radio
104.0 – Radio Emirate FM
107.4 – BBC Arabic Service ... - .- -.
Post #262067 29th May 2014 9:10am
