Home > General (L405) > radio regional change help needed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35280 |
i suspect you would have to replace the tuner with an european one to get the even numbers.. ... - .- -.
28th May 2014 8:22am |
buflanfx45 Member Since: 28 May 2014 Location: middle east Posts: 5 |
Thank you stan for the reply. But would the dealer be able to replace only the tuner?
28th May 2014 10:35am |
i'd have a word with a dealer and ask if this code change is possible, i'm sure you're not the first to import a car in this situation.. ... - .- -.
28th May 2014 10:56am |
USA spec and European spec radio FM tuners are different. I recall this in the days when the Nakamichi TD1200 was only available with a USA spec tuner. Fine if you give it a strong signal and it's on a frequency you can select but generally speaking a US tuner outside of the USA is about as much use as tits on a bull. It has to be changed for a regionally correct one. |
28th May 2014 11:22am |
Thank you for the reply. Just for the sake of discussion this was not the case with bmw. I had 2011 x6 imported from usa and i have found a person that does re coding for the software and changed the regional setting and it was all good. In addition i have seen a thread in this forum to do this chane for RR sport 2012. |
28th May 2014 12:16pm |
the old sport probably uses a completely different firmware system than the very new l405 ...asking the dealer is the first step.. ... - .- -.
28th May 2014 12:31pm |
Maybe contact Steve of Gap Diagnostics. He may know and their IID tool may have the functionality built in to change the region and therefore hopefully the tuner settings MY 2010 5.0 SC Galway green and sand interior!!
28th May 2014 12:43pm |
i have already looked on the GAP site and there isnt a l405 listed [yet ] ... - .- -.
28th May 2014 1:34pm |
I am out of luck, GAP had replied to me that they can not do anything now but maybe end 2014.
29th May 2014 4:31am |
doesnt yours have dab ?.. ... - .- -.
29th May 2014 6:27am |
Faultmate (Blackbox Solutions) does have the L405 software already but their systems are a lot more expensive than the IID Tool. I have a Faultmate Xtreme because I didn't know about the IID tool at the time. MY 2010 5.0 SC Galway green and sand interior!!
29th May 2014 6:37am |
what is DAP??
29th May 2014 8:31am |
Digital Audio Broadcasting ... - .- -.
29th May 2014 9:02am |
can you not enter the frequency manually and save as a pre-set?
29th May 2014 9:10am |
