Home > General (L405) > Non OEM sidesteps
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
Ok, theses any good?
Post #260537 20th May 2014 5:14pm
d3rm0
Perfect! Thank you.
They are almost invisible.
Post #260550 20th May 2014 5:51pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Nice loads better coded slats on the door better lines nice RR Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #260561 20th May 2014 7:30pm
Aeroresh
2014 Range Rover Vogue SDV8 Nara Bronze
To be fair they look almost identical to the OEM ones that I had fitted to mine.
Only difference I can tell is that the OEM ones have Range Rover stamped into the rubber tread plate....but for less than half the price, providing they last the course money well spent Thumbs Up
I like that the alluminium strip along the bottom creates the illusion that the vehicle is lowered when looking side on.
One q though and its one I'm thinking about:-
Front and rear mudflaps?....the fronts in particular will protect the leading edge of the steps '14.5 SDV8 Nara Bronze for sale
'17 BMW 740e Msport Individual on order
'17 Jeep Grand Cherokee SRT 6.4 Hemi on order
'16 Bentley Continental GT V8S Mulliner Driving Spec
'07 Alfa 159 3.2 Q4
'05 Mini Cooper R50
'95 Volvo 850R modified to 400hp
'89 Jaguar TWR ed XJ-S V12 Convertible
Post #260563 20th May 2014 7:38pm
modbarra
Hi, car went in today to have flaps fitted but wrong ones ordered (my fault, car purchased without steps so dealer ordered the associated flaps not knowing steps had been fitted).
Still had a rrs supercharged for the day!
Post #260565 20th May 2014 7:59pm
Googsy
140k on new range rover and non oem steps Rolling with laughter Bow down
They do look good though Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #260566 20th May 2014 8:00pm
Laughing
Post #260577 20th May 2014 9:06pm
Scottyav
Don't worry will be 50k in twelve months Whistle it's like giving a house away for nothing Shocked _____________________________________________________
Post #260579 20th May 2014 9:11pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Thinking of non LR side steps myself as dealer has quoted me £670 +vat for the fixed steps (so £804) or £1118 fitted (incl vat) , so a pair for around £200 fitted myself seems to be the way to go as comparing the 2 , I can't see any significant difference except the lack of the logo as already stated Smile Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #327905 14th May 2015 1:06pm
Shocked Are you looking at the right photo ?
I think they look fine - but would hardly call them almost invisible..... The deployable ones are almost invisible - but very expensive & a PITA Whistle
Post #327908 14th May 2015 1:23pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
These look better than the deployable steps that I have, wish the first owner has spent less and gone this route instead Sad
Post #329773 28th May 2015 11:42am
RRVSE
Ended up buying the LR fixed steps (noticed a Main Dealer was doing 20% off so went to my Main Dealer who immediately price matched) at a cost of £688 incl vat. Fitted them myself, took longer than I thought as the LR instructions don't quite cover everything you have to do - a few more self tapping screws and plastic poppers and brackets to loosen that are not listed. Dealer says 3.5hr job, LR instructions say 2.9 - my time - 6hrs for off side, 5 hrs for nearside - although my time was extended as I didn't have the car on a ramp, just in super-extended mode on my drive so a lot of moving in and out under the car (I did have 2 x 3 tonne axle stands under the normal garage lifting points in case the suspension decided to lower itself!!) and removing and fitting the 2 full length protective covers was pretty tricky. Must say, the only reason the covers are removed is to cut out a 4 sections to allow the step supports to slot in, but they have large gaps where these fit anyway so I can't understand why LR didn't just have larger gaps in the first place so that the brackets could simply be bolted in without removing anything. That along with 14 pre-threaded bolt holes would have been nice, as the position of the holes made it awkward to hand ream the threads with my 10mm tap. Ah well, all done now and they are great, so worth the 11hrs effort I think Smile Steve
Post #332634 15th Jun 2015 5:06pm
11 hours Shocked
How many times did you ask yourself why you'd started it & not just paid someone to do it ?
Post #332675 15th Jun 2015 9:08pm
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
Oh he did !! Laughing Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #332692 15th Jun 2015 10:51pm
RRVSE
Cheers Keith Rolling Eyes
Yes, can see why they charge £300 now. If I'd bought the deployable steps I would certainly have gone down the Main Dealer route as there is far more work involved and I assume a significantly higher labour cost than £300 aswell. Steve
Post #332935 17th Jun 2015 1:30pm
