Home > My Range Rover > LR corrosion warranty
Page 3 of 3 <123
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
What are the side trims being referred to? There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #262329 30th May 2014 5:22pm
read my previous posts Thumbs Up ... - .- -.
Post #262348 30th May 2014 6:54pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
stan wrote:
Craig (ctc) has taken his off..i dont really know what they are supposed to do tbh, unless it channels water some how..
Looking at them they protect the exposed edge of the glass when the tailgate is open. To be honest I am not wholly impressed with the fitting / look of the replacements. One seems to stick out a but further at the bottom the the other. I will take pics soon I am on a busy work period at the moment. As mentioned by lolo there are slight gaps at the end but I suspect these let running water drain away as there is a v cut in them. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #262396 31st May 2014 5:01am
MachineHead
Ok so I looked closely at the trims and...... am I being unreasonable here, please tell me if so.
The left trim sticks out further at the bottom than the right and I think looks pants. Also the corrosion from the old trim hasn't been cleaned off so it is now under the new trim.... acceptable?
Left trim
Right trim
Corrosion
Post #262467 31st May 2014 3:54pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Here is picture of mine to compare.
Post #262474 31st May 2014 4:29pm
rej
Bottom trip removed!! I think mine was stuck on with some type of sealant as it would not side but I cut through then carefully pulled off and it looks much cleaner as I have no side strips either. Bad point was I found more rust and a paint line where the dealer had painted up to the old trip rather than remove it but at least I can treat the rust before it goes back to them again. Looks much cleaner removed There is a difference between knowing your sh!t and knowing you're sh!t
Post #262520 31st May 2014 10:56pm
MachineHead
Well I got my answer, fitted by National Windscreens, Inverness. The same company that caused �680 of damage just changing a front windscreen on my D3 Shocked
They failed to put new clips on the a pillar covers so one came off when driving and they never replaced the engine bay seal after replacing the scuttle panel, so my transmission ECU fried taking the solenoid with it. They paid the bill but even so, it seems they can't do anything on a Landover right, not even simple window trim.
Awaiting a call from them still Evil or Very Mad 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #263962 8th Jun 2014 10:42am
wealy
Anyone else taken these off?
Post #321945 9th Apr 2015 5:12pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Ours a 2004 and didn't come with the side trims fitted. I don't know why Land Rover decided to fit them as the car looks fine without them.
I have just repainted the upper tailgate door due to rust issues and removed the bottom trim. This appears not to be fitted on the later models and will be left off ours. Looks much better and the rubber does not cut into the paintwork causing another problem with rust.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #322008 10th Apr 2015 9:42am
wealy
Do they come off easily enough?
Post #322011 10th Apr 2015 9:54am
vaz
Don't know about the side trims. The bottom trim, I heated it up with a hot air gun and slid it out carefully.
Post #322096 10th Apr 2015 5:01pm
Page 3 of 3 <123
