Home > Maintenance & Mods (L322) > A few Modifications since aquiring her |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
The list is growing on mine as well, an expensive habit!
20th Apr 2014 12:04pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7793 |
I had the 18's on mine when I bought it. Rides very nice, but upgraded to 19's. Now fancy some Supercharged ones.
20th Apr 2014 3:16pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Agree with absolutely every thing you've done except the Parrot Kit. Had the same one fitted to mine and it's the biggest waste of money ever. Temperamental on both the phone and the iPod. Completely over rated piece of kit. |
20th Apr 2014 5:03pm |
A11EXU Member Since: 31 Dec 2013 Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND Posts: 72 |
Maybe i am just lucky - My Parrot has worked perfectly - don't know if it is to do with the fact that all my N/S/R Units are now solely ignition fed - Radio, SatNav, TV, DSP, DAB Radio, Parrot Kit - this was due to a 4Amp draw constantly which would completely flatten battery overnight - think it was SatNav but belt & braces
21st Apr 2014 7:42am |
It was patched in to the original LR entertainment system ( non touch sat nag ), with supposed correct leads made especially for this vehicle. The call volume is particularly low, the voice command system is difficult to navigate, the iPod cuts in and out, it doesn't always pair up with my iPhone on return to the vehicle.... I could go on, the list is endless. |
21st Apr 2014 8:07am |
I thought about a Bluetooth ULF unit and wiring that up - read all the relevant posts and thought
21st Apr 2014 8:52am |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 310 |
I'm getting an L322 4.4 Vogue SE that's had the supercharged upgrares - even says supercharged on the boot but its a 4.4 2003... It has 20" wheel that I was thinking of "downgrading" to 19 inch as the tyres will be cheaper!!! Derbyshire's not a million miles away - if I *do* change - fancy a swap? |
21st Apr 2014 1:07pm |
I've had parrots for years and they've all been good. do you need an SOT for a Vogue SE (L322)? |
21st Apr 2014 1:09pm |
Yes
21st Apr 2014 1:19pm |
TYMH
21st Apr 2014 1:29pm |
21st Apr 2014 1:40pm |
Whats a SOT ? |
21st Apr 2014 9:10pm |
Its the lead you need to convert from a manufacturer's specific radio connection to a standard ISO one which the Parrot kit uses. NO idea what S O T stands for though! it's just referred to as an SOT lead... Tym
29th Apr 2014 12:01pm |
stephen44 Member Since: 19 Feb 2014 Location: IN Posts: 5 |
I believe S.O.T. stands for 'Sound On Top'
29th Apr 2014 1:40pm |
