![]() | Home > Maintenance & Mods (L322) > A few Modifications since aquiring her |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
The list is growing on mine as well, an expensive habit!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
I had the 18's on mine when I bought it. Rides very nice, but upgraded to 19's. Now fancy some Supercharged ones.
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Agree with absolutely every thing you've done except the Parrot Kit. Had the same one fitted to mine and it's the biggest waste of money ever. Temperamental on both the phone and the iPod. Completely over rated piece of kit. |
A11EXU Member Since: 31 Dec 2013 Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND Posts: 72 ![]() ![]() ![]() |
Maybe i am just lucky - My Parrot has worked perfectly |
It was patched in to the original LR entertainment system ( non touch sat nag ), with supposed correct leads made especially for this vehicle. The call volume is particularly low, the voice command system is difficult to navigate, the iPod cuts in and out, it doesn't always pair up with my iPhone on return to the vehicle.... I could go on, the list is endless. |
I thought about a Bluetooth ULF unit and wiring that up - read all the relevant posts and thought |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
I'm getting an L322 4.4 Vogue SE that's had the supercharged upgrares - even says supercharged on the boot but its a 4.4 2003... It has 20" wheel that I was thinking of "downgrading" to 19 inch as the tyres will be cheaper!!! ![]() Derbyshire's not a million miles away - if I *do* change - fancy a swap? |
I've had parrots for years and they've all been good. do you need an SOT for a Vogue SE (L322)? |
Yes
TYMH
Whats a SOT ? |
Its the lead you need to convert from a manufacturer's specific radio connection to a standard ISO one which the Parrot kit uses. NO idea what S O T stands for though! it's just referred to as an SOT lead... Tym
stephen44 Member Since: 19 Feb 2014 Location: IN Posts: 5 ![]() ![]() ![]() |
I believe S.O.T. stands for 'Sound On Top'
