Home > Maintenance & Mods (L322) > A few Modifications since aquiring her
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
Fitted Side Bars
Fitted Rear Mud Flaps
Fitted 18" Wheels and Tyres In Place of the "FinchOver - Stripey Big Cat" or can i just say Overfinch Tigers 22" when purchased
It is sitting in Off Road in Second image (as you will all know)
Had Stage 2 Amplifiers fitted by Baris
Had changed all rear Bulbs to LED - then broke Lamp and "Forced to Upgrade"
Fitted the new LED PowerfulUk Lamps
Fitted a Parrot MKI9200 Phone / Ipod Kit
Fitted Digital DAB Radio
Boot Liner for Dog
Forced to give everything on the Radio Circuit an Ignition Feed in place of Permanent 12V to stop a 4 Amp draw flattening battery overnight
and no doubt others i have forgotten about in last 5 months
as well as a couple of oil changes all filters and a Gearbox Dexron VI and Filter change '54 Adriatic Blue Vogue
Post #255270 20th Apr 2014 11:46am
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
The list is growing on mine as well, an expensive habit!
It looks so different, mainly due to the wheels. I see side bars added as well on yours... 4.2 Supercharged Vogue SE
Post #255274 20th Apr 2014 12:04pm
mjdronfield
I had the 18's on mine when I bought it. Rides very nice, but upgraded to 19's. Now fancy some Supercharged ones.
What do you think to the amp upgrade ? Done mine, very pleased, nice and loud now. Did you have the stage 1 before ?
Mine had side steps from factory. Didn't think I'd keep them, but they are still on after more than 2 years as they save wear to the edge of the drivers seat getting in and out.
Looking good.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #255299 20th Apr 2014 3:16pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Re: A few Modifications since aquiring her
Agree with absolutely every thing you've done except the Parrot Kit. Had the same one fitted to mine and it's the biggest waste of money ever. Temperamental on both the phone and the iPod. Completely over rated piece of kit.
Post #255316 20th Apr 2014 5:03pm
A11EXU
Maybe i am just lucky - My Parrot has worked perfectly Whistle - don't know if it is to do with the fact that all my N/S/R Units are now solely ignition fed - Radio, SatNav, TV, DSP, DAB Radio, Parrot Kit - this was due to a 4Amp draw constantly which would completely flatten battery overnight - think it was SatNav but belt & braces
i had Mki9200 in my BMW and it was great
have my DAB going through Line-In as i have still to do the TAPE Mod to play Audio through the TAPE function
I use the Bluetooth Music streaming and i am just about to load the USB port with some tunes.
maybe yours was a duff unit Sad '54 Adriatic Blue Vogue
Post #255371 21st Apr 2014 7:42am
DaveK
It was patched in to the original LR entertainment system ( non touch sat nag ), with supposed correct leads made especially for this vehicle. The call volume is particularly low, the voice command system is difficult to navigate, the iPod cuts in and out, it doesn't always pair up with my iPhone on return to the vehicle.... I could go on, the list is endless.
Post #255375 21st Apr 2014 8:07am
A11EXU
I thought about a Bluetooth ULF unit and wiring that up - read all the relevant posts and thought Censored
lets take the easy route - OK i cant use the Telephone button on steering wheel but the Parrot answers with accept (Voice commands actually work) and the new unit was different from the one in the BMW as it will now pair more than one phone to answer calls at same time.
Regular updates via the USB port on the Parrot allows latest Firmware patches to allow little tweaks as they become available - having said that i must check if i am running latest update Rolling Eyes '54 Adriatic Blue Vogue
Post #255387 21st Apr 2014 8:52am
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Looking good.
I'm getting an L322 4.4 Vogue SE that's had the supercharged upgrares - even says supercharged on the boot but its a 4.4 2003... It has 20" wheel that I was thinking of "downgrading" to 19 inch as the tyres will be cheaper!!! Smile
Derbyshire's not a million miles away - if I *do* change - fancy a swap?
Post #255411 21st Apr 2014 1:07pm
tymh
I've had parrots for years and they've all been good.
do you need an SOT for a Vogue SE (L322)?
Post #255412 21st Apr 2014 1:09pm
A11EXU
Yes
basically a BMW interface harness as system is really all BMW befor the touchscreen system '54 Adriatic Blue Vogue
Post #255413 21st Apr 2014 1:19pm
A11EXU
TYMH
Sniggering
i am far too honest to swap these wheels - i had a puncture a while ago and decided to get the 18" wheels as a fill in before getting a new tyre, removed the 22"s and 2 of them had been welded and one had been filled and repaired after a rather bad crack on the inner lip - i don't mind driving with them but would feel guilty if someone else was.
they look great from outside but i am sure if driven hard could explode Embarassed '54 Adriatic Blue Vogue
Post #255417 21st Apr 2014 1:29pm
tymh
Shocked Very Happy
No worries... Thanks for the heads up on the SOT...
Post #255418 21st Apr 2014 1:40pm
DaveK
Whats a SOT ?
Post #255487 21st Apr 2014 9:10pm
tymh
Its the lead you need to convert from a manufacturer's specific radio connection to a standard ISO one which the Parrot kit uses. NO idea what S O T stands for though! it's just referred to as an SOT lead... Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #256859 29th Apr 2014 12:01pm
stephen44
United States 2005 Range Rover HSE 4.4 V8 Java Black
I believe S.O.T. stands for 'Sound On Top'
Stephen
USA (originally from London) - 2005 L322 HSE
Post #256869 29th Apr 2014 1:40pm
