![]() | Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
I had some upgraded halogen ones on my TD6 that just fitted in....but the heat melted through the plastic lens eventually.
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Autumn/Winter weather on the way, anyone want to do mine for me ha 2011 RR Autobiography 4.4 TDV8 |
Am I looking for buck converters? 2011 RR Autobiography 4.4 TDV8 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
What wattage are the LED's ? Assuming theyre under 18w look for a 7812 regulator OR a 2.7v zener diode either will do it, the zener diode potentially easier install. BMW i3 Electric Car
https://www.ebay.co.uk/itm/2x-COB-6W-LED-W...2749.l2649
Thanks AJ. I guess the 7812 would be the better option. Not had a look at the wiring yet but do you know if it would it be one 7812 chip per light unit or just the one on the loom? 2011 RR Autobiography 4.4 TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35532 ![]() ![]() |
you are all making a mountain out of a molehill.....
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 ![]() ![]() ![]() |
I have another reverse lamp version build
please edit your post to english frank.. |
Hi Stan , I will make with translator the next minutes |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Fellas, stop messing around with cob panel conversions and fiddling with bulbs that are too long.
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I'd agree with Grofus. His/Bushy's replacement bulbs are perfect. 2010 4.4 TDV8 Vogue SE |
