Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
Ordered and fitted the ones from JPHC's link above and no errors and working fine (2004) only thing is I think the bulbs that were in there may have already been uprated by a previous owner as the light output is actually slightly down (but only a bit) however they are a nice white so that's good |
15th Dec 2016 3:29pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Did a bit of an upgrade on my reversing lights last night, no expense spared, I used a couple of these I had sitting around from a mod I did on my last truck, sick of hearing all these people banging on about their puddle lights in their mirrors I decided to add my own to keep up with the posh pack.
19th Jan 2017 12:33pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
As an alternative to the lens warping 21 watt bulbs I have fitted these as a straight swap for standard bulbs http://www.ebay.co.uk/itm/160858588020?_tr...BIDX%3AIT. Correct off set pins so no messing with holders. They are only an increase of 4 watts each but combined give a total output 20W (close to a normal car reversing bulb) and have made a noticeable difference as in the pics below Standard 6W Bulbs. Right hand with new 10W bulb Both with 10W Bulb Lighting up my approach to the garage Much better levels at night now - at least I can see and the slight increase in wattage wont harm the lens. I'm on the hunt now for a 14W version but at the mo this is an easy upgrade for those that want a simple replacement |
28th Jan 2017 8:36pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
That's all OK if you want to see slightly better, but there is no substitute for LED's, they have a much higher light output.. the Law states the maximum wattage that a given bulb can be, but it was written in the time of normal incandescent bulbs... Manufacturers soon discovered that they could increase the light output with the use of Halogen bulbs, and then HID bulbs... But they are no match to an LED which is much higher in output.. this chart shows the different wattages for the same brightness, and although it's for household bulbs , it shows just how much brighter an LED is..
29th Jan 2017 12:19am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Not viable for the UK I'm afraid. The law limits reversing lights to no. 2 if used on the public highway - MoT fail |
30th Jan 2017 11:12am |
Good point, I suppose anyone going down the route of adding extra lights could wire in a separate switch, even an on/off/reverse switch and run them as working lights..
30th Jan 2017 11:31am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Reverse lights are not a testable under the mot and thus you can't be failed whether or not they are working or even if you don't have them at all. You can fit as many reverse lights as you like as long as the individual bulbs comply with the wattage requirement, easily done with led bulbs.
30th Jan 2017 12:28pm |
Not quite - the Road Vehicles Lighting Regs 1989 (which are still valid I believe) deals with Reversing Lights which it defines as " a lamp used to illuminate the road to the rear of a vehicle for the purpose of reversing and to warn other road users that the vehicle is reversing or about to".
30th Jan 2017 3:58pm |
So if your going to stay within the law either fit new LED's in the existing lamps or fit 2 x 24 watt max LED spots and remove the bulbs from the original lamps... You don't need to be fitting secret squirrel concealed switches and the like, if your that worried about the law, and they wont give a hoot unless you've been a bad boy , fit the spots and disable the candle glow effect lights that LR fitted Yesterday I couldn't spell Engineer... Today I are one!
31st Jan 2017 6:53am |
31st Jan 2017 9:25am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
been reading through this topic and using info from several members and looking around I have found these
31st Jan 2017 10:50am |
They are what I used on my car, only I used 2 panels per light.. but I needed that because my car was factory tint and being pre 2004 included the front windows
2nd Feb 2017 9:42am |
Thanks miggit. do you have a link to the regulators ?? Regards
2nd Feb 2017 9:43am |
I'm fairly sure that they were these http://www.maplin.co.uk/p/l78s12cv-2a-posi...ator-uj56l Yesterday I couldn't spell Engineer... Today I are one!
2nd Feb 2017 10:22am |
