![]() | Home > Camping, Caravanning and Holidays > Towing Electrics |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Hi Stu, sorry I can't help with your question as my electrics were dealer fitted but you'll love the 4.4 TDV8 4.4 TDV8 Vogue Baltic Blue MY11 |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
The electrics are entirely different on the 4.4TDV8 from the early cars... |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
thanks Baron/Craig, not sure if I'm gonna actually do it. Ive just bought a little van for work last month so pennies a bit bit tight and prices taking a tumble on the 3.6 too... |
I just replace the twin 7-pin loom on my 2010 with a single 13 pin kit. It's a lot shorter loom, about a foot all told. No ECU either which makes the kit cheaper. I think the part number you need is VPLMT0007 but best check with Dan to be sure. He'll give you a decent enough price too based on my experiences. |
Sorry to resurrect this guys, eventually got round to buying a 4.4, only took me a couple of years.. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
If twin sockets are already fitted would it not be simpler to have an adapter for the tow electrics? Then you have the advantage of using either.
thanks for reply Weegie, but the only thing I ever tow is my caravan, in the event of needing to tow a trailer with single electrics, I already have a 13 to 7 pin adaptor.
Coding should not be needed if you already have 12N and 12S. The coding is only to tell the car not to use rear park sensors and rear fog lights on the car when you have the caravan connected.
That's just the reply I was looking for. As you say I don't need help reversing, it's not exactly difficult! Mind you always gives me a chuckle when people do!!..I know I'm a very bad person for mocking people.. |
Just a quicky please gents. I have fitted the genuine 13 pin socket and connected the tin tent today for the first time. All the lights work as they should, the fridge works, the fog lights don't come on the FF, but the reversing sensors come on when R is selected. I can turn them off with button on the dash, but I thought that they weren't supposed to come on at all?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8737 ![]() ![]() ![]() |
Need coding into the car with either an Iid tool or at the dealer or someone with autologic etc. There is a different setting for 13 pin and 12n/s There is nothing that can't be fixed with a hammer😜😜
Ah!!.... thanks for that. Will have to get it sorted out, now I know what the problem is... |
All sorted! Bought an IID and reset all the 13 pin stuff. Tried it for the first time today, no more reverse sensors etc... |
