Home > Camping, Caravanning and Holidays > Towing Electrics
stu
Towing Electrics
sorry if this is in the wrong place, but it seemed as good as any to me!!
can someone with a 4.4 TDV8 with towing electrics please let me know if they are the same as all the other model year electrics or are they different?
the reason I ask is I may be upgrading from my 3.6 to a 4.4 and I made a wiring loom up with a single 13 pin euro socket on it to suit my caravan. If things were the same I would remove the loom I made from my 3.6 to obviously save on money. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #253219 7th Apr 2014 5:47pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Hi Stu, sorry I can't help with your question as my electrics were dealer fitted but you'll love the 4.4 TDV8 4.4 TDV8 Vogue Baltic Blue MY11
Post #253269 7th Apr 2014 10:55pm
The electrics are entirely different on the 4.4TDV8 from the early cars... Thumbs Up
Post #253271 7th Apr 2014 11:41pm
stu
thanks Baron/Craig, not sure if I'm gonna actually do it. Ive just bought a little van for work last month so pennies a bit bit tight and prices taking a tumble on the 3.6 too... Crying or Very sad
at least I know the answer to my question now. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #253424 9th Apr 2014 4:37am
mzplcg
I just replace the twin 7-pin loom on my 2010 with a single 13 pin kit. It's a lot shorter loom, about a foot all told. No ECU either which makes the kit cheaper. I think the part number you need is VPLMT0007 but best check with Dan to be sure. He'll give you a decent enough price too based on my experiences.
Post #253438 9th Apr 2014 7:04am
stu
Thumbs Up @ mzplcg Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #253442 9th Apr 2014 7:17am
stu
Sorry to resurrect this guys, eventually got round to buying a 4.4, only took me a couple of years.. Rolling Eyes
@ mzplcg... when you changed to the 13 pin kit was it just plug and play or did you need to do any coding?
I have the original twin LR 12s and 12n sockets but want to change to single 13 pin.
I presume because it is already coded/set up it will not matter unplugging and plugging in a different genuine kit.
Thanks for your help.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434326 9th Apr 2017 8:55am
Weegie
If twin sockets are already fitted would it not be simpler to have an adapter for the tow electrics? Then you have the advantage of using either.
PF. Jones do adapters.
I have 13 pin and do it the other way - an adapter to simplify towing a trailer with single 7 pin electrics. It is a very positive fit to the vehicle.
Don't know if you have looked at their site -
https://www.pfjones.co.uk/12n-and-12s-adap...ocket.html John
GAP iiD BT
Post #434329 9th Apr 2017 9:13am
stu
thanks for reply Weegie, but the only thing I ever tow is my caravan, in the event of needing to tow a trailer with single electrics, I already have a 13 to 7 pin adaptor.
Just like things neat and tidy.
I was going to rewire the two 7 pins into a 13 but can't be bothered to tell the truth. Getting lazy in my old age. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434331 9th Apr 2017 9:21am
mzplcg
Coding should not be needed if you already have 12N and 12S. The coding is only to tell the car not to use rear park sensors and rear fog lights on the car when you have the caravan connected.
Everything just works without coding but the car's fog lights glare off the front of the van and the park sensors drive you nuts when reversing.
There are 2 exceptions I know of to the above statement.
1. If the car has adaptive dynamic suspension. There is a program to stiffen up the back (automatic when trailer connected) and you get the trailer assist program available to you which helps with reversing. You need that huge triangular sticker on the front of the caravan though, which is ugly as sin. Anyone who can reverse a caravan doesn't need it.
2. If the car has surround cameras you get a special view which allegedly lets you see down the side of the caravan. It is not even close to the view in a decent pair of towing mirrors, pretty pointless IMHO.
Post #434342 9th Apr 2017 12:46pm
stu
That's just the reply I was looking for. As you say I don't need help reversing, it's not exactly difficult! Mind you always gives me a chuckle when people do!!..I know I'm a very bad person for mocking people.. Rolling with laughter Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #434344 9th Apr 2017 1:57pm
stu
Just a quicky please gents. I have fitted the genuine 13 pin socket and connected the tin tent today for the first time. All the lights work as they should, the fridge works, the fog lights don't come on the FF, but the reversing sensors come on when R is selected. I can turn them off with button on the dash, but I thought that they weren't supposed to come on at all?
Any help/advice appreciated as usual! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #435417 19th Apr 2017 6:44pm
Need coding into the car with either an Iid tool or at the dealer or someone with autologic etc. There is a different setting for 13 pin and 12n/s There is nothing that can't be fixed with a hammer😜😜
Post #435424 19th Apr 2017 7:42pm
stu
Ah!!.... thanks for that. Will have to get it sorted out, now I know what the problem is... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #435431 19th Apr 2017 8:22pm
stu
All sorted! Bought an IID and reset all the 13 pin stuff. Tried it for the first time today, no more reverse sensors etc... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #439606 25th May 2017 7:30pm
