![]() | Home > General > Mistake ? 2002 l322 v8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Good luck with the compressor, you may be able to gently bend the contacts on the bulb holder so it grips the bulb harder, not sure if it's available separately. Pete
If you are getting hdc and abs warnings as well it may be corrosion on your abs module situated in the rear of the engine compartment in the middle, near the firewall. Sometimes the connectors get a bit of green corrosion on them and this can interfere with the link and as it is a looped system, it sets off other ecus at the same time. Worth having a look inside your abs module. Only a 2 minute job. |
Sorry to hear Paul. I understand what you are going through, my 4.2 SC had a lot of "backlog" work and I also had some unfortunate extra things go wrong :
Paulmeds Member Since: 18 Mar 2014 Location: Devon Posts: 34 ![]() ![]() ![]() |
Hi, thanks everyone. I am hopeful I am getting it right, really does run well & nearly everything is working now !! I am going down the route of making it a good one rather than hoping for a good one. Once the indicator, EAS issues done next on the list is gearbox service & terra clean, make sure all is clean & renewed. Will be nice to finish it all & enjoy hopefully !!
Thanks Haylands, bulb holder worked, £7 fix very rare on this car.
Good luck with it, watch the video a couple of more times, there's nothing tricky to do, will be fine... |
hi, have some free time this week so was going to do the compressor kit but thought I would just check through paperwork on the car and found a receipt for the following - compressor-suspension levelling £299.00 dated 15/2/2012.
Could try cleaning the ABS plug and seeing if that works.... Pete
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
As above, sounds like an ABS problem if you are getting the ABS light on as well as the others. A lot of the systems are interlinked and use each others sensors (ABS,HDC,EAS) so an ABS fault could also disable the EAS (can't tell the speed in order to raise/lower for motorway mode) and HDC which uses the ABS to brake the wheels.
bigdave1947 Member Since: 03 May 2015 Location: United Kingdom Posts: 4 ![]() ![]() ![]() |
Did you have any luck finding someone to repair the pixels in Devon. I have a replacement LCD but dont fancy the job so looking for someone to do it. |
Paulmeds hasn't posted since Oct 2014 on anything so I doubt you will get a reply... several places on eBay that do it and have a quick turnaround...
Many thanks for that I seen a place that for £180 will take the car apart and repair whilst you wait. I dont have a problem with the duff display but on the last MOT the tester put unknown mileage down on the form which cocks up my insurance warranty! I read somewhere that the odometer is stored on the ECU but I have tried to look using Torque Pro with OBD2 and cant find it?
