![]() | Home > Maintenance & Mods (L322) > Wet carpet help!! |
Sunroof drain tubes! Present :2008 TDV8 HSE
Squaresausage Member Since: 09 Nov 2013 Location: Hamilton, Lanarkshire Posts: 22 ![]() ![]() ![]() |
How do I fix them ? Where should I look? What has fallen off today:-) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7898 ![]() ![]() ![]() |
Loads of threads on here if you have a quick search.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
If you open the Sunroof, you will see the entrances to the drain holes in the front corners. Do you have any signs of water failing to drain from the sunroof? (this would suggest a blocked tube or tubes although i would have thought this would also cause the headlining to become damp)
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
mines a leak inside the windscreen side that runs to the footwell, just trying to sort a guy out who knows RR screen fitting _____________________________________________________
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
^ Mine too, was a previously poorly fitted replacement screen.
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 ![]() ![]() ![]() |
Another check is the AC drain tubes perhaps (rear of transmission I think which leave the wet patch under the car). Before the FF I had a Disco which did the wet carpet which I used off-road a lot and the rubber drains got blocked causing the same issue as the drain system overflowed. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
Non-house trained puppy? |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Or it could be this........
Don't think it's the sunroof as poured water down and it drained away fine. Will try windscreen next. What has fallen off today:-) |
Still don't know where it's getting in |
ncurrier Member Since: 30 Sep 2013 Location: bromsgrove Posts: 1 ![]() ![]() ![]() |
Hi
