Home > Maintenance & Mods (L322) > Wet carpet help!!
Squaresausage
Scotland 2003 Range Rover Westminster 4.4 V8 Baltic Blue
Wet carpet help!!
Just noticed that the carpet in the front passenger foot well is wet. Any ideas where the water is getting in? What has fallen off today:-)
Post #249418 20th Mar 2014 5:25pm
Googsy
Sunroof drain tubes! Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #249420 20th Mar 2014 5:36pm
Squaresausage
How do I fix them ? Where should I look? What has fallen off today:-)
Post #249422 20th Mar 2014 5:44pm
mjdronfield
Loads of threads on here if you have a quick search.
As I see it, the upshot is using the nylon cord from as trimmer to feed down the drain tubes from the sunroof tray. The nylon is flexible enough to go round the curves but strong enough to push out most blockages.
Don't use an air line, as it tends to blow the pipe off the connector in the roof, and then you'll really have a leak.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #249425 20th Mar 2014 6:09pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
If you open the Sunroof, you will see the entrances to the drain holes in the front corners. Do you have any signs of water failing to drain from the sunroof? (this would suggest a blocked tube or tubes although i would have thought this would also cause the headlining to become damp)
Also, prob worth checking that the door seal hasnt come adrift / got a bad patch or damage anywhere. Water leaks can be a pig to find, as water travels in such a sneaky manner Crying or Very sad
If you do think the drain tubes are blocked, Heavy Duty strimmer cord is good for unblocking them, but this won't help if the thing has become detached somewhere inside, although it may tell you if you have a detached drain tube as the cord probably won't appear under the vehicle when you expect it to.
Best of luck Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #249427 20th Mar 2014 6:19pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
mines a leak inside the windscreen side that runs to the footwell, just trying to sort a guy out who knows RR screen fitting _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #249428 20th Mar 2014 6:21pm
TugRR
^ Mine too, was a previously poorly fitted replacement screen.
Proper replacement sorted it !
Thumbs Up Where do you go after one of these . . . ?
Post #249436 20th Mar 2014 7:25pm
Ipslore
Jersey 2014 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
Another check is the AC drain tubes perhaps (rear of transmission I think which leave the wet patch under the car). Before the FF I had a Disco which did the wet carpet which I used off-road a lot and the rubber drains got blocked causing the same issue as the drain system overflowed.
Post #249477 20th Mar 2014 9:35pm
Non-house trained puppy? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #249485 20th Mar 2014 10:01pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Or it could be this........
Take the side panel in the footwell next to the radio off and there is a black rubber cap that covers part of the air con /heater xsystem. It's quite common for it to leak so replace it or reseal it with some silicon. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #249508 21st Mar 2014 5:27am
Squaresausage
Don't think it's the sunroof as poured water down and it drained away fine. Will try windscreen next. What has fallen off today:-)
Post #249543 21st Mar 2014 9:39am
Squaresausage
Still don't know where it's getting in Big Cry took the front seat out and removed the carpet all the foam was soaked, the gully where the wiring loom sits was full of water. Dried it out and then soaked it with the hose. No water came in. Poured coloured water down the drain in the sun roof and it came out the drain at the bottom as it should.
Door seals seem fine too. Will keep looking. Sad What has fallen off today:-)
Post #249587 21st Mar 2014 12:30pm
ncurrier
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
Hi
Did you manage to find a solution to your problem? I seem to have a very similar problem, passenger footwell getting very wet after heavy rain and particularly if parked facing downhill, making me think the leak is from the rear somewhere and running forward. Since parking uphill no leaks even after heavy rain???
Post #284735 6th Oct 2014 10:50pm
