![]() | Home > Maintenance & Mods (L322) > New steering wheel. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
pm sent, thanks. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Nice, did you get them working wirelessly then? please tell us more !!! This reminds me I have a set of these paddles that i will not need either, so for sale for cheap too. Cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
I used 'the wizzard' matt Stevensons youtube to wire them in to the centre console, using the heated wheels existing wires. -as I got the wheel for £150 (new) it made my decision for me not to have the heated function. it wasn't hard to wire up, but finding an earth for the wires on the wheel meant I had to wedge in a connection, unless I drilled a small hole to steering wheel body, the wedge method works though. and the lights work on the paddles too. very dim, but nevertheless there. I could have tidied up the leather on rear of paddles a bit more, but not knowing if they would last past testing... I didn't finish them perfectly, and they still look good. you cant really drive like lewis Hamilton with them, as they go round with steering wheel. but as said, I use them, on motorways etc.
En Vogue Member Since: 22 May 2014 Location: Munich Posts: 41 ![]() ![]() ![]() |
Hey verydisco,
You can STILL use your heated wheel with that method too sir ![]() Wire the illumination power to the heated steering wheel circuit & the earth to the black earth wire (spade connector on the airbag) From memory, the black earth wire is split into two circuit's so check that first! The 2 led's will be the tiniest of current use so won't overload the heated steering wheel circuit... That then free's up the two wires from the illumination circuit (the up/down paddle's just send an earth signal so, very thin wiring will be fine) ![]() |
Big Tings Member Since: 03 Apr 2015 Location: Vogue Posts: 22 ![]() ![]() |
So for those that have fitted the heated wooden type steering wheels would you recommend them ? |
So decided to go the piano black route and it's nice and warm. Definitely worth the money !!
