Home > Maintenance & Mods (L322) > led upgrade
Page 4 of 9 <123456789>
not familiar with the navcoder software , but if you look at the options there might be something that indicates this.. ... - .- -.
Post #85203 3rd Oct 2011 10:01pm
daveo
if poss try to avoid using resisters they can get very hot and i mean very hot. i have tried the new cree led's ones i bought, crap Exclamation they are great in the colour range but just dont give out any light,you just end up with a round spot of light in the middle of the light unit. V8 facelift Range Rover Autobiography 22" wheels.
Post #85215 3rd Oct 2011 11:51pm
oohh! that's a bummer...i'll stick with my 18 smd jobbys then, tbh, they give out enough light for drl's... ... - .- -.
Post #85225 4th Oct 2011 8:32am
Post #85226 4th Oct 2011 8:32am
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
not sure if I am missing something here....
so its right to say that if you want rid of the 'bulb' effect from the front of the FF, the only way to do this is with led lights and resistors? I am sure I read an alternative way of using led's but without the resistor? (from another forum maybe??)
Post #85256 4th Oct 2011 3:27pm
Reformed
If yours is pre touch screen I am sure you can turn the error message of using navcoder, the fogs do show up on the Navcoder interface. I am going to get some and thats what I plan to do. Reformed
Post #85263 4th Oct 2011 4:06pm
leds/smds take less power to operate than a normal bulb so the FFRR thinks one/two bulbs are out and so shows an error and displays that, one way to solve that is by fitting resisters in parallel to the led/smd ...another method is buy leds/smds with a canbus error circuit which fools the FFRR into thinking there is a proper wattage bulb ... ... - .- -.
Post #85265 4th Oct 2011 4:09pm
liverpoolphil
Yeh its these canbus ones I've read about, anyone a suggestion / recommendation, last time I looked on the bay, there were loads of em Thumbs Up
Post #85282 4th Oct 2011 5:17pm
depends what bulbs you want to replace, but try ebay or hids4u .. ... - .- -.
Post #85283 4th Oct 2011 5:20pm
liverpoolphil
The 2 side light ones stan, seen thee on the bay http://www.ebay.co.uk/itm/RANGE-ROVER-L322...591wt_1185 and wondering if I should just get them and see how they are
Post #85292 4th Oct 2011 5:40pm
they'll do the job phil...tbh if you don't mind the 2/3 second flicker on start up you could get the normal ones... ... - .- -.
Post #85296 4th Oct 2011 5:49pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Will somebody be so kind as to post the bulb types for each upgrade please?. H7 for the fogs etc, my book doesnt list them like this and i have to tell hids-direct what i want so he can do me a deal. Dont want to order a fitment that doesnt work or is too bright, he suggested 8 SMD LED's for the side lights suggesting that his 5 SMD would be too blue.
Hope its not too much trouble, the bulbs id like to do initially are, fogs, side lights, number plates and interior.
Thanks
Carl
Post #87677 16th Oct 2011 6:46pm
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
http://www.autobulbsdirect.co.uk/custom_mo...master.php in the interests of impartiality, other bulb suppliers are available Laughing
Post #87686 16th Oct 2011 9:03pm
algt2
[img]http://www.flickr.com/photos/44875651@N03/6250711203/[/img]
Post #87687 16th Oct 2011 9:12pm
carlos50
What about the front fog lights, will the H11 LED CREE projector type bulbs be suitable or is it better just to get HID Xenon white bulbs?
Post #96909 9th Dec 2011 7:32pm
