Home > Maintenance & Mods (L322) > led upgrade |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35339 |
not familiar with the navcoder software , but if you look at the options there might be something that indicates this.. ... - .- -.
3rd Oct 2011 9:01pm |
oohh! that's a bummer...i'll stick with my 18 smd jobbys then, tbh, they give out enough light for drl's... ... - .- -.
4th Oct 2011 7:32am |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 |
not sure if I am missing something here....
4th Oct 2011 2:27pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
If yours is pre touch screen I am sure you can turn the error message of using navcoder, the fogs do show up on the Navcoder interface. I am going to get some and thats what I plan to do. Reformed |
4th Oct 2011 3:06pm |
leds/smds take less power to operate than a normal bulb so the FFRR thinks one/two bulbs are out and so shows an error and displays that, one way to solve that is by fitting resisters in parallel to the led/smd ...another method is buy leds/smds with a canbus error circuit which fools the FFRR into thinking there is a proper wattage bulb ... ... - .- -.
4th Oct 2011 3:09pm |
Yeh its these canbus ones I've read about, anyone a suggestion / recommendation, last time I looked on the bay, there were loads of em |
4th Oct 2011 4:17pm |
depends what bulbs you want to replace, but try ebay or hids4u .. ... - .- -.
4th Oct 2011 4:20pm |
The 2 side light ones stan, seen thee on the bay http://www.ebay.co.uk/itm/RANGE-ROVER-L322...591wt_1185 and wondering if I should just get them and see how they are |
4th Oct 2011 4:40pm |
they'll do the job phil...tbh if you don't mind the 2/3 second flicker on start up you could get the normal ones... ... - .- -.
4th Oct 2011 4:49pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Will somebody be so kind as to post the bulb types for each upgrade please?. H7 for the fogs etc, my book doesnt list them like this and i have to tell hids-direct what i want so he can do me a deal. Dont want to order a fitment that doesnt work or is too bright, he suggested 8 SMD LED's for the side lights suggesting that his 5 SMD would be too blue.
16th Oct 2011 5:46pm |
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 |
http://www.autobulbsdirect.co.uk/custom_mo...master.php in the interests of impartiality, other bulb suppliers are available |
16th Oct 2011 8:03pm |
[img]http://www.flickr.com/photos/44875651@N03/6250711203/[/img] |
16th Oct 2011 8:12pm |
What about the front fog lights, will the H11 LED CREE projector type bulbs be suitable or is it better just to get HID Xenon white bulbs? |
9th Dec 2011 6:32pm |
