Home > Maintenance & Mods (L322) > puddle lights in wing mirrors of vogue on a 54 plate
Page 3 of 4 <1234>
Weegie
p38arover wrote:
Generally, when people have LED issues (and it's not a polarity issue), they put a low value resistor in parallel with the LED, not in series, to increase the current flow though the sensing circuit.
Out of interest, what value resistor is suggested? John
GAP iiD BT-Sold
Post #401557 22nd Aug 2016 2:20pm
i think those little 501 bulbs are only about 2/4 ohm John , so not to big.. ... - .- -.
Post #401568 22nd Aug 2016 3:38pm
Weegie
Thanks. Stan. Thumbs Up John
GAP iiD BT-Sold
Post #401659 23rd Aug 2016 10:31am
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
HI FOLKS
just to re confirm something, are you saying to wire the old bulb in line with the led ( in series) or ( in parallel ) ??
bob Embarassed Rolling Eyes
bob
Post #402651 30th Aug 2016 7:43pm
parallel Bob, just to load the wiring with resistance..you only need one side done...luckily the contacts on the old bulb bend out easily for connecting a wire or soldering .. ... - .- -.
Post #402652 30th Aug 2016 7:47pm
BOBCUSSEN
hi stan
ok great thanks a lot; cant wait to have both sides blazing away in blue Thumbs Up
kind regards bob
Post #402665 30th Aug 2016 8:28pm
alistairh
Thread resurrection Laughing I've had this issue today! In non electrical terms would one if you lovely gents explain what I need to do to wire in a resistor and what type of resistor..the diffrence with the led is quite noticeable so I'm determined to get this working
Post #423140 16th Jan 2017 9:15pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Don't know what the problem is.
I've put led's in both my door mirrors, and they work perfectly.
Post #423145 16th Jan 2017 9:28pm
alistairh
Either do I ..I've tried 3 different brands of led so it's not the bulbs. The one that does work has made a big diffrence. A lot more illumination from it compared to the old bulb..
Post #423210 17th Jan 2017 9:48am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Wow these white are bright Thumbs Up
https://www.amazon.co.uk/dp/B01G6TT9SW?psc=1 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #423236 17th Jan 2017 11:26am
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I sorted this problem on my '06 by unfolding the wires on the old build and pushing the wires of the old bulb down inside the holder where the wiring goes into the holder, few drops of glue to hold them in place and then just refitted the holder into the mirror.
Post #423579 18th Jan 2017 9:16pm
^ good idea.. Thumbs Up
Post #423584 18th Jan 2017 9:41pm
proser
Like the idea hamlet Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #423589 18th Jan 2017 9:56pm
alistairh
Post #423610 18th Jan 2017 11:00pm
BOBCUSSEN
so by doing that with the old bulb, does that do the same thing as soldering a resistor across the wires ?
bob
Post #435309 18th Apr 2017 7:00pm
Page 3 of 4 <1234>
