Home > Technical (L322) > Test Glow Plugs, ECU and Relay - Identification of parts?
Working on my prolonged starting time.
Youtube has helped with how to test glow plugs although they appear to be a Censored to get to on the FFRR, but just to check:
Quote:
Once connector removed from glow plug, simply attach multimeter to end of glow plug and positive battery terminal. If voltage same as battery (pos to neg) then glow plug OK, if nothing then dead. I understand glow plugs are like light bulbs, they either work or they don't? Can some one please confirm this as OK for FFRR TD6 ?
I have been looking in my "E" box too, which is where the glow plug ECU and relay are. Need some help identifying all the parts and also on any methods to test the function of the ECU and/or the relay. Want to check these are working before moving onto the glow plugs which require a bit more dismantling:
1. Glow Plug ECU
2. Glow Plug relay or other ?
3. Glow Plug relay or other ?
Some more photos inside the E box
IIDTool has always given me this fault, prior to the poor starting
Quote:
“3505 Unknown (Engine)”
Glow plug relay failure - glow relay defective. - detail from GAP
Price for new relay from Dan is £94, but this must be for the ECU (Number 1 in photo) ?
Thanks .
Post #238731 1st Feb 2014 1:17pm
bump .
Post #238907 2nd Feb 2014 10:56am
dingg1
http://workshop-manuals.com/landrover/l322.../page_574/
that should help you
Post #238912 2nd Feb 2014 11:12am
Yep
but confusion arises from this extract from RAVE (from changing e box fan section) ?
So is it a relay or an ECU? I will presume the former.
Now how to test if it is working OK ?
Probably nothing like the glow plug relay but this video is useful: #t=488 .
Post #238935 2nd Feb 2014 12:25pm
dingg1
I'd say relay - just sloppy terminology calling it an ECU
link with vid showing various ways to check relays,
www.squidoo.com/how-to-perform-an-automotive-relay-testing
no-one local able to swap a known good one to try on your car?
Post #238937 2nd Feb 2014 12:36pm
Well, the connectors are nothing like the relays in the howtos, a big single post for the output power and 11 small pins for the connector, and I couldn't get it off the little plastic board it is fixed to, but with finger on the relay and ignition switched to position 2 I can feel it click, then there is a quiet electrical crackling sound.
There are lots of the same relay knocking about on eBay 2246919 72RB510 for @ £40. Good example with images:
http://www.ebay.co.uk/itm/BMW-E39-E46-3-5-...1344729221
Will have to check glow plugs next.... .
Post #238955 2nd Feb 2014 2:32pm
dingg1
use multimeter to earth and top of glowplug should be about 0.9ohms resistance (iirc)
you don't need to pull them to check them
Post #238960 2nd Feb 2014 2:56pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Joe, the glow plug relay/ecu can be tested simply by checking that it is putting 12v to the glow plugs when you first turn on the ignition. The big red wire is the feed from the battery to the relay and there are 6 individual wires going to each glow plug so you would have to check each 1 for 12v. To test the glow plugs, disconnect the positive wire on the end and check for continuity with your multimeter from the positive terminal of the glow plug to ground. If it shows an open circuit then its faulty. However, i think you are barking up the wrong tree regarding your starting probs as it happens when hot or cold. You would be better doing a leak off test on your injectors first. Its a very simple test you can do yourself with some hose and small clear bottles. Have a look on 'you tube'. Next to check would be the fuel pumps. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #239467 3rd Feb 2014 11:40pm
Thanks for the advice wats39 & dingg1.
Ran the tank dry (more or less) and filled up with fresh fuel, no change so can rule that one out too (long shot)
Mpg seems to have dropped off by 1 or 2 on this tank full, but no smoke from rear, and still running fine.
Will have to have a go at glow plugs and leak test this weekend Thumbs Up
Some wiring images
Post #239636 4th Feb 2014 5:28pm
OK, carried out glow plug test today. Just to ensure i have the science right, removed connector from glow plug relay, then connected multimeter to +ve terminal of battery and inserted -ve lead from multitester into each of the connectors for each glow plug. A reading of 12v + indicates glow plug working OK.
If this is the case, I only have two working glow plugs!! (One gave a very small current flow but I count this as broken). No wonder it is struggling to start!
Off to have a word with Dan Wink .
Post #245429 28th Feb 2014 9:50am
Glow plugs @ £16 each all in from Duckworths Thumbs Up .
Post #245449 28th Feb 2014 12:06pm
Frosty this morning, 0 degrees, FFRR took nearly 15 seconds to fire up (chatata chatata ad infinitum!) so definitely glow plug related! .
Post #246185 4th Mar 2014 9:38am
It was all going so well, inlet manifold out, correct deep socket applied, then bang, the nut on the glow plug parts company with the threaded end of the glow plug, on four of them!! Evil or Very Mad Evil or Very Mad Evil or Very Mad Really only applied medium pressure to undo, and gave some heat as well.
Guessing this is a head off job to have them drilled out?
Only saving grace is that one of the ones that wasn't working has started working, so at least I have three doing a job for now (Cylinders 1, 4 & 6) Big Cry
Hmm, found this but in situ would be tricky, and £120 + for the kit .
Post #247084 8th Mar 2014 1:49pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Hm, found this? but no link Question 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #247090 8th Mar 2014 2:32pm
mjdronfield
link works for me. Click on the word "this".
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #247100 8th Mar 2014 3:24pm
