Home > Technical (L322) > Test Glow Plugs, ECU and Relay - Identification of parts?
That looks to have the potential to go wrong quickly....... Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #247101 8th Mar 2014 3:34pm
URLs could do with being a bit more visible... .
Post #247103 8th Mar 2014 3:36pm
Engine needs to be as near as possible to full running temperature when removing glow plugs
Post #247109 8th Mar 2014 4:24pm
Yes, there is an argument for and against this:
Cold; the metals and threads are "decompressed" and therefore not under tension, supposedly making it easier to undo
Hot; the metals and threads are compressed, under tension but the heat can produce less friction, supposedly making it easier to undo
Given the relatively light touch I applied to the plugs, I don't think it would have made much difference? I did put the hot air gun one of the plugs for a few minutes, the hex still span Sad
It is all past that point now, FFRR starts up after a few turns of the starter motor, so all is not lost, apart form having four brand new glow plugs in stock!
I would have a go at extracting them, using something like a reverse thread extractor drill/bit, but would worry about the inner core dropping into the cylinder when I break the top of the plug off .... .
Post #247130 8th Mar 2014 6:59pm
