![]() | Home > Maintenance & Mods (L322) > fitting exhaust trims |
Did you paint the exhaust box? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3783 ![]() ![]() |
that sounds better than a few V8's I have heard in L322's ! |
Great noise!!!! |
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
Anymore pictures of the full car from the back. Also what did you paint the back box with? mine could do with a quick coat. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35618 ![]() ![]() |
excellent job dave..i also painted my exhaust which looks very similar to yours but mines a diesel.. ... - .- -.
What paint did you use? |
You can buy spray can heat resistant black paint in Halfords in matt Black (or silk) but even better and cheaper is heat resistant BBQ black paint also available in Halfords!
strangely enough its called 'DIRECT TO METAL PAINT' [honest] brought from wickes..i didnt clean or sand down the exhaust , i just painted it straight on...i also done the towbar and anything else i could find under the back... not the best of pics but it gives you an idea. ![]() Y. O. L. O. . Last edited by stan on 1st Oct 2010 5:06pm. Edited 1 time in total |
stove paint also works well, and its usually very hard wearing / steam cleaner resistant |
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 ![]() ![]() ![]() |
Hi daveo them exhaust trims look mint you say £100 for pair did they make them especially for you or are they off the shelf item, if made for you could you give me the length so I can order a set the same cheers Range rover hse
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Hi daveo,
Walshy Member Since: 18 Dec 2016 Location: Nottingham Posts: 8 ![]() ![]() ![]() |
Anyone know what mm the pipe is that comes out of the backbox? Looking at doing something similar on my tdv8.
