Home > General (L405) > White Smoke From exhaust.
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi all, I have a MY 14.25 SDV8 That releases a lot of white smoke from the exhaust sitting idling at the lights intermittently the smoke comes and goes. The temp out side sitting at around 35+ degrees there is no power change or rough running of the engine, just a lot of smoke that can be seen in my mirrors or blowing past the car. Any thoughts on what is going on ?
Post #237841 29th Jan 2014 2:11am
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Condensation from the exhaust?
Post #237846 29th Jan 2014 7:36am
GregMilner
Australia 2012 Range Rover Westminster TDV8 Fuji White
I had this problem with my previous car, a RRS 3.0TDV6 - clouds of white/blue smoke on acceleration, it was embarrassing. It was under warranty, the dealer/LR spend 6 months trying to fix it (they put it down to a turbo problem with that 2010 model year), eventually they gave up and shipped a new engine out from England.
I'd be going back to the dealer with it right away. 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Gone: 2010 RRS 3.0 TDV6, 2007 Audi TT 3.2V6 Roadster
Post #237851 29th Jan 2014 8:23am
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
There is s TSB on this. LTB00524v3 - 4.4 SDV8 Exhaust Smoke
Post #237860 29th Jan 2014 8:50am
jettec
Thanks guys I will pass on the info in the TSB, the car is going in next Wednesday I will let you know how it goes.
Post #238175 30th Jan 2014 3:23am
jettec
HI guys turbo oil scavenge line modification carried out no more smoke nice going JLR I can not fault their service
Post #241575 10th Feb 2014 6:29am
kudos to Matt for supplying that TSB. Thumbs Up
Post #241583 10th Feb 2014 8:22am
jettec
Hi guys the white smoke has appeared again, Had a little look under the car and found oil just below the L/H turbo where the turbo joins the exhaust connection , so its back to the shop for the turbo this time to be replaced and the front suspension struts as they are knocking and rattling when one wheel hits an irregularity in the road surface. The dealer had to get JLR to approve the repairs first. Will let you all know how this goes.
Post #248713 17th Mar 2014 6:47am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
bang on front is the ARC not the struts , its a known issue Far to many gone...
Post #248716 17th Mar 2014 7:47am
jettec
Thanks thoner001 your info is just great, otherwise they like to blow smoke where the sun don,t shine. Knowledge is a powerful tool.
Post #248900 18th Mar 2014 1:55am
